The First Thing To Purchase...cky3100 04-12-2004, 04:39 AM what should i order first my deck my subs n wiring kit my amp or my box? bumpinstang77 04-12-2004, 11:15 AM head unit doesn't matter when you order, but your not gunna be workin w/o it. Get your subs then an enclosure for them. Then get an amp to match them. Then get an install kit w/ the right guage wire. Haibane 04-12-2004, 11:29 PM Wow... I really disagree. The one thing you will always regret not having is a good headunit, I would get the headunit first, then you can run RCAs instead of whatever is used on stock. Also I would see if you can make an enclosure based to sub specs aznxthuggie 04-13-2004, 12:11 AM that is some DAM GOOD advice haibane, i wish someone told me before i bought an amp.. i got subs from my aunt for free, so i got an amp, that matched the rms (also a mistake) at first i had to buy the amp, then the LOC or line output converter, it sounded so crappy, til i bought my head unit, then everything became clear, this was how i got my system started PaulD 04-16-2004, 09:54 PM if you KNOW you don't want the OEM (factory) headunit, it might be easier or cheaper since you won't need a LOC. It's always cheaper to buy what you want the first time. Automotive Network, Inc., Copyright ©2012
