Boost controllers...which one?91CRXHF 04-12-2004, 12:06 AM im lookin into a boost controller right now i plan on buying one in the next week or so i have done some research but want other opinions. i have a 91 CRX with a B18A1 that has a T3/T4 turbo and custom manifold the head has been ported and polished and has a high performance gasket the valves are stanless steel and have titianium valve springs. i have a turbo cam adjustable cam gear. JE lower (not the lowest forget actual number its too late right now) compression pistons. Eagle H beam rods blue printed and balanced engine. Moroso oil pan....uh...i think thats about it...the engine is all done and the swap should be starting this week i am waiting on the mounts and the Quaife diff. so anyways back to what i NEED TO KNOW which is which digital boost controller while have NO or better chance of not having boost spikes and which is the best bang for the buck. im lookin at Blitz, Greddy, HKS and...Apexi. -Thanks DeleriousZ 04-12-2004, 03:02 PM here's a review of some of the boost controllers you were talkin about... maybe it'll help ya out http://www.sportcompactcarweb.com/tech/0207scc_boostcontrol/ 91CRXHF 04-14-2004, 02:00 AM ya i read that site alrdy i saw you posted it in another thread and it did not help me much because that was done an internal wastegate and how am i suppose to know that the results would be the same on an external which is what i will have but thanks anyways DeleriousZ 04-14-2004, 05:52 PM results will most likely be the same if not better... internal wastegates are known for their problems with boost creep.. an external wastegate would function better, therefore most likely yeild better results just a thought Automotive Network, Inc., Copyright ©2012
