Caravan Fan stays on!
rukool
04-09-2004, 09:26 PM
My wife just came home in our 1998 Dodge Grand Caravan. The fan won't go off when the key is off! I tried turning it back on and putting in gear, but that didn't help. The fan has been on for about thirty minutes. Any suggestions of fixes? Thanks!
knucklebuster2
04-09-2004, 10:43 PM
On many vehicles, the rad fan will stay on even when the ignition is turned off until a certain temp is reached, then it will shut off.
michelq
04-10-2004, 07:19 AM
under dash left side of dash next to body control madule
blower high speed relay need to be replaced
rukool
04-10-2004, 08:51 AM
Thanks for the reply! Now the battery is dead! How much to replace the part mentioned? The van has a remote start, is this a problem? The fan just stayed on until the baterry gave out. Any other suggestions?
Thanks
michelq
04-10-2004, 01:35 PM
about $15 for the relay
tcopes
04-14-2004, 08:56 PM
The fan relay needs to be replaced. It is located behind the air filter assembly (air filter assembly has to be removed) and screwed onto the main frame rail. As a temporary solution you can remove the fuse located under the hood, drivers side to shut the fan off but put the fuse back in before you start the vehicle or engine light will come on.
sammar
05-07-2004, 12:36 PM
you have to replace the thermostat if the fans stay on all the time.It happened to me before.
sem520
05-27-2004, 06:31 PM
There is a recall on the cooloing fan relay. It's a pretty old recall I think it's 771 recall..check with your nearest dealership
