engine swap..2.0->3.0
eurobeaner
04-09-2004, 08:18 PM
My friend has a 95 dodge neon 2.0 dohc...he blew the engine and wants to get a new one. I'v heard that a 3.0 v-6 out of a stealth will bolt right in...BUT... i was wondering if the wiring harness's would match up...(correct me if im wrong, i thought the engine out of the stealth was a mitsubshi with a dodge tag on it) im going to be the one doing the swap so i dont really want to tell him to buy the v-6 that wont even work..just wondering if you all knew anything about it??
jaronervin
04-11-2004, 01:35 PM
www.neons.org has a detailed set of instructions on how to swap a 3.0 into a neon, i think.
blachdohcneon
04-11-2004, 07:56 PM
dont think a 3.0 will go in but the 2.4's are pretty close to a direct swap. Also the mitsubishi bought their engines of dodge, the eclipse uses a toned down version of the neon dohc.
drag1320neon
04-13-2004, 01:50 PM
the eclipse is an exact version of the dohc, just backwards. as far as the 3.0 into a neon, doubtful bolt in, fab, maybe, 2.4 a def. go for that
eurobeaner
04-14-2004, 12:11 AM
alright cool......thanks for the info, ill tell him that..
eurobeaner
04-14-2004, 12:17 AM
ok....now i got another question...with the 2.4, if i were to put it in....would it use the same ecu and wiring harness?? cause i can get an engine for 375$ but dont kno if i need the harness and everyhing
blachdohcneon
04-14-2004, 11:56 PM
the 2.4 has the same head as the dohc, so a 2.4 uses the same sensors and pcm as the dohc, although the 95's are slightly diff then the other years, but its not a big deal at all, swap in the 2.4 it will rip.
also the eclipse version of the dohc is 140hp unlike the neon's 150hp
eurobeaner
04-15-2004, 12:05 AM
ok.....now....my friend's dad said we cant swap the motor cause they put the 2.4 in the caravans and his neon is a 5 spd and the motor wont handle a manual, he said it wasnt made for a manual so it cant handle the strain it will put on it and the life of the engine will greatly decrease.....i dont think this is true, i dont think they make a beefier engine for a manual car....he said if you put an engine that has been in an automatic into a car that is a manual it will not last as long...i think its all bull.....what do u think
ohh....and can u get performance mods for a 2.4.....it is out of a caravan.....iv never heard of a pimped out caravan with 300whp...
FuriousMachine95
04-15-2004, 12:15 AM
The 2.4 is what they put in the new pt cruiser. They are 5 speed manual as well as auto. There is a shit ton of stuff you can do to it. The biggest difference between the manual and auto of a 95 2.0 sohc is the throttle body. The one off the auto is bigger than a manual. Cheap bolt on if you can find one in a junkyard. I got mine for 30 bucks. I don't know if the 2.4 is the same way or not though... Might be worth checking in to.
FuriousMachine95
04-15-2004, 12:20 AM
Or you could always go with the 2.0 magnum engine. Has as much hps as the dohc.
