Egine chek light is on.. T.TMOMOG20 05-04-2001, 12:59 AM dose anyone know how to reset the computer!?!?!? my engine check light is on after install my header!!! Kenny-G 05-04-2001, 02:23 AM You got your O2 sensor hook up? Wires broken? I think you need a scanner to reset the check engine light. If you want I can look up in the computer in my shop too see if there is a switch or anything on the ECU. primera man 05-04-2001, 06:01 AM Yep....i think it sounds like a shop job to reset the computer. G-Forces 05-04-2001, 09:03 AM If all the O2 sensors are hooked up correctly and they haven't been damaged you could try disconnecting the battery for a couple hours. That should reset it. Oh yeah make sure the O2 grounding strap is connected properly too. MOMOG20 05-04-2001, 11:31 AM well i made hold in my bottom of my header so i already put 02 senser in it!!! i don't think it's from the senser... and i tried unhook the battery for couple hours but it didn't work that way!!!! i don't think it reset the ECU!?!?! well let me know if anyone know how to reset EUC by the other way not unhook B... thx guys ^.^ Kenny-G 05-05-2001, 02:30 AM Hey MoMoG20! I know you are online right now..I need to know what year is your G, auto or manual, CA emission or not? MOMOG20 05-05-2001, 10:51 AM mine is 2000 and manual transmission Kenny-G 05-05-2001, 11:53 PM Oh 2000? My shop's computer data is up to 98....that...I would recomment you to call Jwt up and ask them. You probably don't want to let your dealer know that for now. Or I would try a new O2 sensor. The sensor may got damaged when you put your header on. MOMOG20 05-06-2001, 12:49 AM thx in advice!!! ronnie_g 04-01-2002, 01:40 AM You mean this pain in the butt light? I got rid of it by following the manual on how to reset and check the fault code on the ECU unit. First, find out the fault code on your ECU. Then keep trying at least 3 times if the code will remain the same on 3 trials. I thought I had to change my EGR valve because it gave me the code for it. I tried the 2nd time, it still was code 32. Then, after the 3rd time, the code went to 55 w/c was freakin' normal. So, after that 3rd trial, the light was gone!!! This freakin' light went on for about 3 weeks! Maybe it was a matter of luck for me, but try it! http://files.automotiveforums.com/uploads/305062CheckLight.jpg G20t ECU: http://files.automotiveforums.com/uploads/375822ECU3.jpg Automotive Network, Inc., Copyright ©2012
