transmission light onjhedm 04-08-2004, 12:10 PM I had a problem with a burned out fuse for the power outlet. Since I did not have a fuse diagram I pulled every single fuse to check if it was bad. Needless to say the fuse for the power outlet is located slightly above very other fuse, thus is was the very last I pulled. I had even checked the fuses of the main electrical distribution center already :-(... After this ordeal the transmission light in the instrument panel stays on. Doublechecked all fuses, all are ok. What could be the problem? jhedm 04-08-2004, 12:45 PM Forgot to mention: I had misplaced one fuse and the Jeep would not start until I had corrected this. Could the light be on for a stored failure code? Can this be reset? Automotive Network, Inc., Copyright ©2012
