Blower (fan) only works on highjtavares 04-08-2004, 09:15 AM I have a 96 voyager and yesterday, when I turned the heat down one notch from high, it turned off. It only works at the highest setting. I saw one other person post this, but he never got a response. Any ideas would be greatly appreciated. I'm either cooking or frozen! ha ha! Jennifer jreichert 04-08-2004, 01:35 PM This just happened to me last month. The blower fan speeds are controlled through a resistor block that is mounted in the engine compartment on the top of the firewall on the passenger side. There is a connector going to it with 4 wires. It is very easy to replace(just two screws) and only cost $12 for a new one. Be carefull to inspect the connector and clean the contacts if possible. One of the contacts on mine melted part of the connector and I also had to replace it. Only the first three speeds go through the resistor block. The top speed is full power to the fan. Hope this helps. Joe Automotive Network, Inc., Copyright ©2012
