97 Cherokee w/ rear end vibration when decelerating
cordy74
04-08-2004, 09:09 AM
I've got a '97 Cherokee Country, 4.0L, 4WD with 110,000 miles on it that hums and vibrates when I decelerate. The vibration happens when I let my foot off the gas and does not stop until the Jeep comes to a stop. Vibration frequency is consistent with speed (decreases as speed decreases) and occurs with or without braking and in Drive or Neutral. I've checked out the U-joints and they all look and feel solid. It seems to be coming from the rear of the Jeep but I can't be completely positive on that. The vibration also disappears if I put my foot back on the gas and accelerate. I'm afraid the rear differential might be going out on me but don't know for sure. Any comments or suggestions?
Cherokee98
04-16-2004, 02:07 AM
Hi, i have a similar problem, my 98 cherokee often (not always) shakes when i go over a 100km/h and then when i slitly press on the brakes it shakes even more and i often have to let go the brakes to make it stop shaking. It also shakes when i switch lanes at about 100km/h. Any comments will be appreciated.
Dale Aeppli
04-16-2004, 07:06 PM
HI I WOULD RECHECK THE UNIVERSAL JOINTS THEY CAN BE BAD & UNLESS YOU DROP THE DRIVESHAFT & CHECK THEM BY REMOVING THE DRIVESHAFT SO YOU CAN ACTUALLY CHECK THEM BY HAND FOR TIGHTNESS IF YOU JEEP IS A HIGH MILEAGE VEHICLE IT MIGHT BE WISE TO DROP THE DRIVESHAFT & CHECK. IF YOU DO DROP IT ON YOUR OWN BE SURE TO YOU HOLD THE 2 CAPS ON THE REAR UNIVERSAL JOINT. DON'T LET THEM FALL OFF THE NEEDLE BEARINGS WILL FALL ALL APART. THE DRIVE LINE CAN HIDE A LOT OF SLACK THAT YOU CAN'T NOTICE, WHEN IT IS IN PLACE DALE jeepman600@aol.com
