Tire PressureRicochet 04-07-2004, 04:00 PM I'm going to the strip tomorrow for the first time this season, on my stock steelies. Both fronts are at the stock-rated 30psi, but what will give me less wheel hop and spin? I can't really guesstimate the pressure over and over and go launching around the roads I live near but if somebody can give me a ballpark figure I can do the rest.. thanks. XixGenuinexiX 04-08-2004, 02:10 AM i think around 24-26psi but don't hold me to it. Check around www.clubsi.com under the drag section i believe. civicHBsi91 04-08-2004, 11:28 AM drop to 25 psi, then drop to 20 psi and i have gotten my best times on 15psi yes 15psi its called test and tune for a reason :) Ricochet 04-08-2004, 01:31 PM cool thanks, I'll try those out. A mod on clubsi said to drop the tire pressure to 30psi, so maybe he typoed and meant 20..? DVS LT1 04-08-2004, 04:25 PM 20, 22 is good. I don't excatly know whats at work within a V6 or I4 or H4 (especially the motors that are mounted sideways under the hood), but for rear wheels drive V8 & V6's I've heard that it helps to lower the tire pressure of the rear drivers side tire about 2-3 psi compared to the rear passengers side tire. I usually race both rear tires at 20-22, but this spring I'm going to try 18-21 in the rear left and 20-22 in the rear right. Try looking to see if some guys use different tire pressures for the front L&R. Ricochet 04-08-2004, 09:42 PM Nobody around had an air compressor so I just ran at ~29. My best time was a 14.9@92mph, not too shabby with little track experience with this engine. I'll be hitting mid/low 14's by season's end. XixGenuinexiX 04-08-2004, 10:57 PM Nice, how many runs did you get in? Ricochet 04-09-2004, 12:15 AM Only ran 3 times, got a little crowded. 15.0 twice, then 14.9 I really need to work on my launch. civicHBsi91 04-09-2004, 02:43 AM what do your 60's look like?? 60' is the key!!!! Ricochet 04-09-2004, 03:00 AM f'in horrible.. 2.4 and 2.5 civicHBsi91 04-09-2004, 10:50 AM yea thats deff horrible, try running on your 17's next time even tho they are bigger you'll get more grip or drop the psi, you would have been fine driving home or to a gas station to refill them back up on lower psi Ricochet 04-09-2004, 01:27 PM I'm going for brackets next wednesday. I'll mess around with the pressure then and see what's best. civicHBsi91 04-09-2004, 07:47 PM drop drop drop it like its hott, 29 is tooo high kingpinn 04-21-2004, 04:41 AM trust me start at 22 and go down slow. but dont go under 14 they can wrap under and thats no fun........thats just my take.... damir831 04-21-2004, 01:07 PM Hey Ricochet, this is off topic, just checked your profile, are you a 92 Alpha or Yankee? Ricochet 04-21-2004, 03:43 PM 35 foxtrot, night vision (and 168 other electronic things) repair damir831 04-21-2004, 04:08 PM Oh ok, I saw "logistics" in your profile so I thought you might be a 92 series. I was an alpha. Automotive Network, Inc., Copyright ©2012
