Grand Cherokee Electric Fan
BigJem
04-07-2004, 03:40 PM
The electric cooling fan on my 1999 Jeep Grand Cherokee will not turn off, even with the keys out of the ignition. I have turned off the AC (per the amber inside switch) and even turned off the fan with no success. The only thing I can do to save my battery is to disconnect it. HELP!
Dale Aeppli
04-08-2004, 11:52 AM
HI, THERE IS A BLACK BOX RIGHT BEHIND THE BATTREY WITH RELAYS & FUSES TURN THE LID OF THE BOX. YOU WILL SEE SOME LITTLE BLACK BOXES ABOUT 1 INCH SQUARE. THESE ARE RELAYS ,ON THE LID YOU WILL SEE 1 MARKED COOLING FAN IF THE FAN IS RUNNING TAP THE RELAY MARKED COOLING FAN,IF IT TRIPS THE FAN OFF THE RELAY CONTACTS ARE STICKING. IF THIS IS THE CASE SWITCH THE RELAY WITH ONE OF THE OTHER RELAYS THEY ARE ALL THE SAME IF CHANGING THE RELAY WORKS,NAPA SELLS THEM $8.00 HOPE THIS HELPS DALE jeepman600@aol.com
Dsilver
04-09-2004, 04:38 AM
This guy knows what he is talking about. Take his advice.
:iamwithst just kidding man. :grinno:
BigJem
04-11-2004, 02:03 PM
Dale, thank you very much! Problem fixed.
Dsilver
04-22-2004, 10:08 PM
Dale is welcome, if you ever have a question just ask him, he is the all knowing all seeing Oracle of the Jeep. :)
cybertiger
06-07-2004, 08:00 PM
I have a 199 grand cherokee that had the same problem...but now the relay has finally died....i bought a replacment but need to know where it goes....the black box under the hood with the relays does not have a relay that says cooling fan....only a fuse...that says that...i've replaced it and still nothing....so i need to know where the cooling fan relay goes for my jeep???
thanks a ton!!!
Dale Aeppli
06-07-2004, 08:20 PM
thanks a ton!!!
Hi you left the last number in the year of your jeep,email me and i'llsee if i can come up wiht something to help you dale
jeepman600@aol.com :smokin:
cas297
09-21-2004, 01:42 PM
My 99 jeep cheokee limited has a similar issue but the fan will not turn on. if i go over a bump or turn hard the fan will kick on but other then that it stays off. I also put my hand in front of the vents and the faster i go the more air will blow out. it is very cold so i believe it is A/C. I think it might be a bad fan switch on the control panel of the dash? Anyone else hear or see this issue and know how to resolve it.
Craig
chrys
11-06-2004, 09:12 PM
I found me having this problem you never said where it was located.
hundahunta
11-07-2004, 01:25 PM
I think this year, the fan relay may be located behind of the front bumped on the frame of vehicle
blorenz
12-28-2004, 01:51 PM
2003 GC: My fan does not switch on. I checked the fan and it works when directly connected to the battery, so it has to be related to something else. Does anyone know what the relay looks like to try switching. I switched the two bigger square ones, but it did not fix the problem. Any other ideas?? Thanks!
ArLouJeep
12-29-2004, 10:35 PM
ok guys, here is what I found, I have a 2001 JGC, that the fan realy went out on, the fan worked fine when attached directly to the battery, I got the relay, which by the way is a dealer only item. It is located behind the facia, under the battery, on the passenger side fenderwell. You have to remove the headlight, and front facia, although there is a chance that you can remove the passenger headling, and cut a hole in to reach the relay, two simple bolts hold it in.
