toe or camber?
S14K
04-06-2004, 12:23 PM
my tires are wearing out on the outside edges of only my 2 front tires. what is the reason of this also wat can i do to fix it
J SPEC SilEighty
04-06-2004, 01:40 PM
that would be your camber. did you lower your car? get a camber kit and then get it aligned
S14K
04-07-2004, 12:05 AM
yes my car is lowered
manji240
04-07-2004, 05:53 PM
ya you have to get that aligned after you lower it.. if its not real bad i dont think you need a camber kit.
R.W.240
04-07-2004, 06:15 PM
wait, Relative to the car is it the outside of the tire or the inside? I belive the inside should be wearing if your lowered and camber is the Problem
Either way get an Aligniment
S14K
04-07-2004, 06:33 PM
ya i got it aligned right after i lowered it and the wearing occurs on the outside
J SPEC SilEighty
04-07-2004, 07:07 PM
get a camber kit then and you should be able to dial it in to how you want it.
and yeah, rw240 is right, after you lower it it should be the inside of the tire that is wearing.
