96 Caravan Power LocksNebil 04-05-2004, 11:51 PM Recently purchased a 96 Grand Caravan and really like it. Got it for a good price and the only thing I can find wrong with is that the power locks can behave a little funny if you inadvertently depress the power switch down when the locks already down if I said that right. You hear the motor whirr for a second. This usually comes from the driver's door but can also come from side door. Could this be a relay switch problem? Would be interested in hearing if anybody has same issues before I take it to a stealer..uh..dealer. Thanx. Bill helinut222@msn.com 04-08-2004, 06:08 AM I bought a new 97 and the dearler changed the drivers door lock twice and both sliding doors once.Luckly it was under warranty. So I just bought a used 97 a few months ago the drivers door lock does the old buzzing noise. It doesnt hurt any thing you may have to hit the switch a few times to get it to lock or unlock. I went to a junk yard and got three locks two worked ok the the third buzzed. There is a rotory arm in side the lock that doesn't catch all the time and what you hear is the motor spinning inside it. The slidding door switch can be fixed with a little epoxy but the front doors are glued together and are almost impossible to get apart. Hopes this helps... Nebil 04-09-2004, 12:04 AM Thank you, yes that did help. I recently went to the dealer to see what recall work was done on this vehicle and while I was there I looked around their used car lot and tried the doors on a '96 and it was really bad. I now hear that this was common on the '96, '97 models. Is it simple to get the door panel off on these things? I noticed you puchased another '97. You must have had a good experience with the first. The downside of visiting these forums for advice is that you have to swim through all the scary things that have happened to people...If I hadn't already owned VW, Chev, Ford, Nissan, Toyota, Honda...the list goes on, I would think that these problems were unique to Caravans. Thanks for your comments. Bill helinut222@msn.com 04-09-2004, 06:07 AM So far I haven't had any major problem with mine. Considering everyother mini van out there is a caravan they cant be to bad there is always going to be a few lemons. The door panels aren't to bad to get off, you may break a couple of those plastic clips that hold it in place though. When I went yo the junk yard I grabed a hand full of them. The sliding door lock has a little rubber boot on it you move the boot and uder the boot there is a stop that breaks, a little epoxy on it a it will work fine...generaly... The drivers door is a different design lock I tried to fix it and it didnt work. They glued it together and you almost have to destroy the lock to fix it. Hope this helps... Amin Automotive Network, Inc., Copyright ©2012
