R.P.M...Help?crazy__one 04-05-2004, 09:42 PM Why does my 1993 Grand Chreokee Larordo??? What causes the RPM s to not work when I am in low gear (automatic} or at an idle??? When you put on the gas it works ..shifts etc....The RPMs gauge jumps around at a idle and when doing 35 or less put on the gas and they start working........Thank You ????? How and what do I do to fix this.....Thank you all so much......... leowolf 06-13-2004, 05:54 PM Replace the Idle Control Valve located behind the throttle body. here is the site to order it, you will find it under fuel injection then: idle air or idle control: http://www.partsamerica.com/PPF/SourceArea//DestinationPage//PartType//PTSet//year/1993/make/JEEP/model/GRAND+CHEROKEE/submodel/LAREDO/SearchFor//VehicleEngine.asp leowolf 06-13-2004, 06:02 PM Replace the Idle Control Valve located behind the throttle body. here is the site to order it, you will find it under fuel injection then: idle air or idle control: http://www.partsamerica.com/PPF/SourceArea//DestinationPage//PartType//PTSet//year/1993/make/JEEP/model/GRAND+CHEROKEE/submodel/LAREDO/SearchFor//VehicleEngine.asp You will need a #25 torx bit on a 1/4 inch ratchet to change it. crazy__one 06-14-2004, 05:57 PM Thank you so much Havent been on in a while..I will have that changed asap...Again Thank you Automotive Network, Inc., Copyright ©2012
