No thermosthatjhredd 04-05-2004, 03:19 PM Hi, if I leave the thermosthat out will it cause any problems with the computer or bring on any other problems? My jeep has ran warm and sometimes hot since I bought it about 2 mos ago. It had a new thermosthat in it but this weekend it ran real hot and would not take any water so I knew it was stuck. I pulled it out and it only opens about 1/8" or so and sticks. I know the enginewill take a little longer to warm up but was wondering if I leave it out instead of replacing it if i will be ok as far as the ecm is concerned? Many Thanks, JR redteamleader 04-19-2004, 09:45 PM hey man welcome to jeep. every one i know has problems with over heating. the main problem you will find is with jeeps craaaaapy resivior bottle. leaving out the stat will not cause any problems as far as i know. mines been out for about 6 months. BIGJEEPMAN has great advice on over heat problems Dale Aeppli 04-19-2004, 09:58 PM [QUOTE=jhredd]Hi, if I leave the thermosthat out will it cause any problems with the computer or bring on any other problems? My jeep has ran warm and sometimes hot since I bought it about 2 mos ago. It had a new thermosthat in it but this weekend it ran real hot and would not take any water so I knew it was stuck. I pulled it out and it only opens about 1/8" or so and sticks. I know the enginewill take a little longer to warm up but was wondering if I leave it out instead of replacing it if i will be ok as far as the ecm is concerned? HI JR YOU SHOULD REPLACE THE THERMOSTAT ACTUALLY IT HELPS THE COMPUTER SEND THE RIGHT SIGNALS TO THE SENSORS. the computer needs the heat to make engine running adjustments DALE EMAIL jeepman600@aol.com Dale Aeppli 04-19-2004, 10:16 PM Hi, if I leave the thermosthat out will it cause any problems with the computer or bring on any other problems? My jeep has ran warm and sometimes hot since I bought it about 2 mos ago. It had a new thermosthat in it but this weekend it ran real hot and would not take any water so I knew it was stuck. I pulled it out and it only opens about 1/8" or so and sticks. I know the enginewill take a little longer to warm up but was wondering if I leave it out instead of replacing it if i will be ok as far as the ecm is concerned? Many Thanks, JR HI JR, THE COMPUTER NEEDS THE HEAT THAT THE THERMOSTAT CREATES TO RUN THE SENSORS CONTROLING IT. IF YOU NEED INFORMATION I'LL GLADLY SEND YOU INFORMATIOM ON THE COOLING SYSTEM. ALSO I'LL SEND A SHEET ON HOW TO CONVERT OVER TO THE NEWER OPEN COOLING SYSTEM. EMAIL ME AT jeepman600@aol.com AND I'LL GET OUT TO YOU DALE :banghead: BCBlues 04-20-2004, 02:21 AM Heres the deal on the open system cooling system conversion compleat with part numbers. I did it to my jeep and it worked so well I posted it a while ago. http://www.automotiveforums.com/vbulletin/showthread.php?t=206558 spooleffect 04-21-2004, 02:09 PM Yeah um, no thermostat is a really stupid idea. Automotive Network, Inc., Copyright ©2012
