My ABS light comes on a lot and I called an Infiniti repair shop, they said that it was a common problem with p10's. This is how they told me to fix it, Look at the black box on the left of the ABS and hit it, not extremly hard but firm. This will cause the ABS light to go off. This isn't fixing the problem it's just saving you from a dead battery. The problem is the ABS relay is burnt out and that causes problems. This is what the infiniti dealer told me. They said if I brought it in that they could either fix the relay or do that as a quick fix. It worked for me, hope the information helps.
