I want to upgrade my stock GST95-GST 04-01-2004, 10:33 AM HI, I just got a 95 GST w/ 81k a few months ago....I really love my car, but I don't want to be all stock. I am getting some money in a couple of weeks-mid april- ($2500). I don't want to be one of those stupid kids that spend money in useless stuff. I would really appreciate any advice on what to buy. For instead. get a double turbo or one big one....or something like that (I love the sound of the turbo makes).....I want to spend first on the performance, rather than in the looks (although my girl will brake up w/...... :thefinger ) I hate when a car looks great, but doesn't do much. BlackBlur 04-01-2004, 10:59 AM Go to www.cheapturbo.com, look at the Garrett turbos or the T-series if you got the $$$ and want big results. -Upgrade the blow off valve- 1st generation eclipse -Get a bigger front mount intercooler- Spearcos are nice -Maybe an exhaust, I personally like the stock ones. But thats your call. Hope that helps a little bit. joemathews 04-01-2004, 11:03 AM Yeaah...check out www.dsmtuner.com and look at their recommended upgrade path. Also worth checking out are www.buschurracing.com, and other threads on AF. There isn't a production "double" or twin turbo kit for the GST or GSX. But then again, when you can run sub-8 second quarter passes on just one turbo, do you really need another? :iceslolan don't think so There should be plenty of tips and suggestions for what to do next on the above sites. Good luck! BlackBlur 04-01-2004, 11:07 AM But watch out, dont get too much power...unless you just want to buy new tires every week. My only regrets about the Talon TSi 2wd. 95-GST 04-02-2004, 11:55 AM Those pages really help a lot....thanks......I got another question.... I've noticed that when I go at 50 mph + and push my brakes the whole car starts to shake.....and I also noticed that the front wheels are worn out. Should I rotate and balance my tires or just get two new tires for the front and have them balance??? soyee7 04-02-2004, 11:57 AM The shaking is probably from warped rotors, either get them turned or buy new ones. For your tires i would buy new ones, you dont want to take the risk driving on baled tires. Import2nr99 04-02-2004, 05:56 PM either your alignment is out or you have a brake problem. Probably rotors like soyee said. I would replace your tires, all 4. it's spring and you don't wanna get stuck in the rain with shitty tires once that turbo spools (I found this out the hard way... but damn was it fun) Get some diecent ones. Kumho's are good an cheap. about 360 for a set of 4 17's. and less if you have the stock rims. Have your mechanic check out your brakes or do it yourself if you know how. Good luck 95-GST 04-05-2004, 07:41 PM Im gonna try first to rotate the tires.....(since they are not that bad)......and balance them (i need to do that anyways)....thanks though......I heard that when you get or upgrade a turbo , and after you install the intercooler your A/C will be gone...?...is it true???.....what happens if you tune your stock turbo?....i heard that they put a chip or something like that to boost it.....and finally...does anyone know any cheap-homemade mod's that are not high tech and can be done in an afternoon?.....I really apreciate any suggestion...thanks JoeWagon 04-05-2004, 07:56 PM 1. A/C and intercooler are un-related. 2. Tuning your stock turbo makes a stock car more in-tune (what did you expect?) 3. There's a factory device to control boost to stock levels, yes, and..? 4. http://www.dsmtuners.com/tuning-guide/2gturbo/stage1power.php http://www.roadraceengineering.com/2gupgradepath.htm http://www.jumptronix.com/2g_go_faster/index.htm those free mods: http://www.dsmtuners.com/tech.php check the links at the top too. 95-GST 04-14-2004, 09:34 AM Thanks.......I just noticed another problem with my stick shift.....it used to be very smoopth when I shift and downshift......but now when I go up to the third gear and want to downshift to secon it kind of back me up....I mean I can still downshifting, but I can go all the way to the left and down...... (do I make my self clear? :banghead: ) I can still shifting correctly, but I know that is not normal...... overboost05 04-15-2004, 11:01 AM Exhaust (2.5-3 inch NO CAT) Intake (make sure you can reciculate the BOV) BOV (greddy) Boost Controller (Manual works fine) Boost Gauge (auto meter is a good brand) If you still have money you can opt for a larger turbo and then work on fuel managment... Big t28 Killer or a Big 16G turbo are great starters You will then need a walbro 255 fuel pump, possibly larger injectors, apexi AFC, and prbly a pocket logger. A larger Greddy or Apexi FMIC coudlnt hurt either. Check out www.dsmtuners.com ;) 96spyderman 04-26-2004, 06:26 PM My thoughts are... 1. K&N air filter or equal 2. More high flow exhaust. At least muffler. 3. 1st Gen BOV 4. Turbo upgrade...check out ebay..some good ones show up for pretty good price for new. 5. As for tires...I just put on 4 called FUZION.. sold at tires plus and elsewhere. Great tires and awesome grip!!! good price too!! 6. Strut brace makes all the difference... especially on the convert's! 7. Oh yeah... bigger intercooler with new turbo... 8. Send your ECM in for performance chip... mine gave me from 20-28HP gain. That would be a pretty good start... http://www.cardomain.com/id/96spyderman That there is my cardomain page... Come one come all...thanks for lookin...please no haters. RattlesnakeGST 04-26-2004, 06:41 PM 1. Free Mods 2. 1g bov and a boost gauge 3. Injen or K&N FIPK 4. 3in Exhaust+Downpipe 5. Put $500 away cause somethings gonna break at the most inoppurtune time... That way you wont be moping around the house cause youve spent all your money on go fast parts and dont have money to fix it.. 6. Save up more money for a clutch to hold your new found power... That should keep you busy for a while... :) And im not kidding about number 5... Cause my friend is currently learning that lesson the hard way... Spent all his money on parts... Transmission went out 5 weeks ago.. Hes drivin the beater to work cause he doesnt have the money to get a new tranny installed.. causing his girlfriend to lose her job cause she was drivin the beat to work and now has no way to get there... 97_3clipse 04-26-2004, 07:14 PM JUST GET THE BASICS to star with k&n FIPK - $110 cat-back exhaust - $500 bov - $200 (greddy S-type) dejon tools uicp - $200 boost controler - $120 boost gauge and pod- $145 97_3clipse 04-26-2004, 07:19 PM and if your going for that RICER look dont forget about: -hood pins -seat covers -steering wheel covor -non-painted bodykit -huge spoiler -rims and tires (but dont lower the car) -exhaust tips that light up -AND THE COOL CIGARETTE LIGHTER THAT GLOWS AND STUFF 95-GST 05-07-2004, 02:50 PM yeah that's sounds good.... :screwy: .....i got a question.....am i better off with a new bov or should I just go and head for the junk yard and get one from a 1g ??? and if so, can i get it from ANY 1G or it has to be a gst/x....(they are harder to find)....or from a talon esi or something like that.....(don't know much about talons....)....what else can i get from a 1g that i can use for my 2g? ashah000 05-07-2004, 03:02 PM Talon esi is the NT one. Talon tsi is the turbo. << I think those are right. Yes you need the from the turbo models, the NT ones wont have a BOV. 95-GST 05-13-2004, 04:27 PM thanks, black cars are a pain......i have one myself too......how do you keep it neat?..........so is it better (cheaper + reliable) to get a bov from a 1g than a new one? ashah000 05-13-2004, 05:32 PM Read the FAQ.. at the top. It is cheaper How do I keep it neat LMAO well right now it is covered in dirt :( I usually wash it every weekend. 95-GST 05-13-2004, 07:16 PM did u paint your dashbord silver or you change it and put some metallic one......it does look painted......did you order the a/c lay out and everything else in metal istant of the stock lay out? ashah000 05-13-2004, 07:25 PM The dash is not painted it's still black. But the a/c thing and the other parts that look silver are painted silver Nstyle29 05-13-2004, 08:02 PM How exactly did you do that to your tail lights, and think that would look good on an all white eclipse? ashah000 05-13-2004, 08:24 PM They are covers and the center is painted... search for the taillights thread started by me. I don't know how that would look on a white eclipse, it would be interesting to see. You could always photoshop it :) Automotive Network, Inc., Copyright ©2012
