Converting Yukon XL headlights to Denali Lights
revvin
04-01-2004, 09:01 AM
Does anyone know if you can convert the headlights for 2003 Yukon Xl to Denali headlights or HID lights?
Thanks
Eggert
04-02-2004, 12:00 AM
I have a 2001 Yukon XL and am looking for HID too. I think someone makes replacement headlights, just don't remember details. Any suggestions? Thanks.
revvin
04-02-2004, 08:46 AM
Found a website www.plasmagarage.com, they have conversion kits for Yukons
tonytone
04-02-2004, 08:00 PM
If you want to install HIDs in the stock Yukon headlight housing, then you'll need to get a 9006 HID retrofit kit; if you want to swap out the stock Yukon headlight housing for the Denali look, then just get the Denali headlight housings--they'll fit right in, except they require 9005 bulbs. If you want the Denali housing AND HID, then get the 9005 HID retrofit kit along with the housing. The Denali housings typically aren't cheap, but you might get lucky and find a set for a good price on Ebay.
Short of finding a projector headlight housing designed for HID and putting in a true HID non-retrofit kit, the Denali housing/9005 HID retrofit kit is the best way to go if you have the money...plus, the Denali headlight projector housings are better--both in form and function--than the plain old Yukon ones.
Eggert
04-06-2004, 01:26 AM
Sylvania has HID replacement headlamps for Chevy and other trucks, but not GMC.
www.sylvania.com/xenarc
The Sylvania kit will not fit for the Yukon, as the Chevy headlights are not as tall as the Yukon ones. (sigh...).
They do have a rectangular fog light / auxiliary low beam light kit.
That fits the Yukon, but not the Denali, which has round fog lights.
http://www.sylvania.com/xenarc/x1010.htm
So, I will take tonytone's advice and get the Denali (projector) lamps and then add an HID bulb kit.
Who has quality Philips or Osram HID kits?
Thanks again, Eggert.
Eggert
04-07-2004, 01:08 AM
If you guys can stand one more post...
I called Sylvania about if they were planning a Xenarc HID X2020 kit for the GMC's.
They informed me that they are getting out of the HID kit business due to low demand.
Does anybody know, if the Denali projector type headlamps are much better than the regular Yukon reflector type ones?
About $400-$500 better?
tonytone
04-09-2004, 07:25 PM
You can't be too unhappy going the Denali projector route, but like you said yourself, is it worth $400-$500 more? I was thinking about buying a set for my regular Yukon, but couldn't pull the trigger on paying that much for just projectors...so I just bought a Denali instead. Gotta love that kind of weird logic, eh? :naughty:
Eggert
04-15-2004, 12:34 AM
Hi tonytone, I can see that you solved your problem...
I thought about getting a Denali.
As for the headlamps, I just got an OEM pair for $260 on ebay... here is the link, they have a bunch of truck stuff
http://stores.ebay.com/MARTINS-AUTO-PARTS-AND-TRUCK-ACCESS_W0QQsspagenameZl2QQtZkm
They also are off ebay on the net at http://www.truckefx.com/
This may be helpful for others looking for stuff for newer trucks/SUV's...
Take care, Eggert. :bananasmi
tonytone
04-16-2004, 08:10 PM
That's a pretty good price for OEM Denali projectors!
Eggert
04-23-2004, 12:17 AM
Hi guys, I just put the new Denali headlamps in, they even came with new Philips 9005 bulbs.
:naughty: They are a worthy improvement, :naughty: as the beam also has a wide part to it, similar to a H4 or fog lamp.
Highly recommended. Take care, Eggert :bananasmi
Jlogan9
11-11-2004, 04:58 PM
are the denali headlights a direct plug and play replacement for the standard yukon headlights? I am very interested in doing this and I am trying to get an idea of how much work this will be...
Thanks...
tonytone
11-12-2004, 03:05 PM
Just make sure that they (assuming you're talking about OEM Denali headlights, not aftermarket ones) come with the correct headlight connector plugs, since the standard Yukon headlight connector plugs directly to the bulb, whereas the Denali connector plugs to an aux connector on the Denali headlight cluster itself, then there is a separate wiring harness on the cluster itself that plugs to the bulb. This is so (IIRC) because the Denali uses 9005 bulbs for low beam.
YukonJen
11-12-2004, 06:24 PM
Have just purchased a pair of after market Denali assemblies for my 03 Yukon and have run into the plug problem. Does anyone know of the aux plugs mentioned being available after market? Any other suggestions for mateing the 9005 blubs to the Yukon?
Eggert
11-12-2004, 09:40 PM
Hi YukonJen, it is not a big deal to do. You just take some material off the inside of the connector to accept the 2 ridges of the bulb (instead of just one ridge). The factory projector headlamp has a plug converter harness piece on it.
Here is what I posted some time ago in a thread titled "Yukon and Denali"
Link to the whole thrad:
http://www.automotiveforums.com/vbulletin/showthread.php?p=1798547#post1798547
There is one modification you must make:
Both Denali Hi and Low beams are 9005. The old low beams are 9006. This is not a big deal, but you must make the groove on the light bulb connector wide enough to accept the two ridges from the bulb.
I used a drill and a kitchen knife. Be careful, the plastic is quite soft.
Take care and happy carving. Eggert Johnson :bananasmi
YukonJen
11-16-2004, 09:16 PM
Hi Eggert,
Thanks for your help! I did what you recommended and it works great!
Thanks again!
YukonJen
stagalv
11-20-2004, 03:06 PM
Now that you got your Denali head lights. How can you make them to where the hi & low beams stay on at the same time OR to where the aux. driving/fog lights stay on when the hi beams are on? Does anyone know of a quick fix to this? Would this draw too much power and hurt anything?
Eggert
11-21-2004, 08:41 PM
Hi stagalv.
There are no provisions for combining high beams with either low beams or fog lights. :cya: It does not have any benefit. :( It also is illegal. :nono: Yes, there are some :screwy: outfits that slap some relays together. You may have seen their smart sounding :smokin: ads.
You will be all set already if you have the projector lamps. They work very well. :bigthumb:
From a functional perspective, everybody would drive with high beams all the time, if it was not for blinding oncoming traffic.
The low beams have to be limited in range for that reason.
Therefore low beams will not add anything useful with high beams already on.
Fog lights are for driving conditions with poor visibility, meaning slower speeds. The beam is wide and short to help you see the side of the road so you do not wander off it because you can not see anything to begin with. They are mounted low to pass under the fog, as it is less dense close to the road surface.
That is why high beams in the fog will blind you with reflected light. :shakehead :22yikes:
Fog lights can be used as short distance fill-ins to the low beams. It will brighten things up a little bit. Many people seem to do it.
I did not mean to be so long-winded, may be it is the German in me... :cheers:
Take care, Eggert Johnson :bananasmi
tonytone
11-22-2004, 03:14 PM
Eggert--it is also illegal in the U.S. to replace OEM halogen headlights on a vehicle with any HID headlight kit (with the possible exception of the Sylvania kit for the NBS Tahoe/Suburban) at this time, yet you were looking to get such a kit for your truck--let alone failed to even mention this fact... ;)
Eggert
12-05-2004, 09:31 PM
Hi tonytone, may be I should have followed this up. :uhoh:
I did not get HID lighting :crying: as I found out that the bulb kits are illegal :eek: and Sylvania was not planning to do Xenarc HID X2020 replacement lamps for the GMC trucks. :mad:
The projectors are a big improvement over the regular ones and all I need. :thumbsup:
tonytone
12-06-2004, 02:19 PM
Eggert--I did not mean to sound critical in your not mentioning that aftermarket HIDs are illegal; I only mentioned it because you had stated at one point that you were considering getting some and I hadn't seen a post indicating whether you were gonna get them. In any case, I'm happy that the projectors are working out for you--they're a much better choice on the Yukons than the OEM non-projectors...
