high port vs. low portGVR-4&a90Si 03-31-2004, 10:59 AM I have the opportunity to buy a clean '93 G20, but it is going to need an engine. I read that the 91-93 had a "high port" and 94 on had "low port". Is this a reference to the intake port location? If so, the manifolds are not interchangeable correct? If I buy an engine online how do I know which one to get? Most ads say "fits Sentra, G20 etc blah blah". I tried a Google search to find better engine specs but just got flooded w/ crap. This would be my first SR20 powerplant so bare w/ me on the noob questions. If anyone can link me to a good page for a swap in a '93, your help is appreciated. Thanks, Chad mcguiver7 04-29-2004, 01:21 AM 91-93 were high port intake manifolds. which means that the manifold is shorter and you'll be able to notice it because the injectors are easily accessable. the high port motors had a beefier intake cam that adds about 5hp. these motors were OBDI 94-96 were low port intake manifolds. which means that the manifold was longer and kinda wraped around the injectors. its kinda confusing cuz they called it the low port but the mani was actually higher up then the high ports. with these motors they switched to a less beefier intake cam but they were able to gain the hp back with the new mani fold design. these motors were OBDII 00+ were roller rocker motors w/ obdII but for some reason Jwt cant crack the code on these ecus yet therefore they are untuneable. so if youre thinking about getting this 93 g20 then get the high port motor or just drop a sr20det in it :naughty: or you could just turbo your stock de motor like i did. Automotive Network, Inc., Copyright ©2012
