What is a "quad driver module"
1995_riviera
03-31-2004, 08:19 AM
I´ve had the error codes scanned on my 95 Riviera and they indicated error 640: QDM 1 Fault.
I found out this is a quad driver module, but where is this part, so I can check it?
Thanks, Lutz
michelq
04-08-2004, 07:23 AM
quad driver built inside PCM which control several componant such as boost control solenoid,evap purge valve,and tcc solenoid inside transmission
1995_riviera
04-13-2004, 04:51 AM
Thank you for the detailed information!
Could the tcc solenoid inside transmission report an error if the transmission oillevel gets low?
I had a supplemental oil cooler installed befopre the error occured...
