door panel removal
ronnjr
03-30-2004, 11:04 PM
Hello, I have a 1999 T&C limited. does any one know the proper way to remove the door panels. I have taken them part ways off but I think there is one more screw holding it on :banghead: . Any advice I would be greatful thank you.
rrichard7
04-09-2004, 09:57 PM
Did you get the 2 at the base (below the map pockets) through the carpet?
ronnjr
04-10-2004, 10:24 AM
Yes, the 2 screw's at the bottom were removed. But the thing I'm worried about is at the top of the door by the window control's and on the side panel seemed to be stuck. I don't want to yank on it an break something. Maybe I should invest in that door panel removal tool..Thanx
lisavern1
07-09-2005, 08:57 AM
HEy can ya help out a guy here! I need to replace the passenger side mirror thanks to my newly licensed daughter) and I do not know where to begin in removing the inside door panel on my 1999 Chrysler Town & Country. Where are all the screws located? Door panel removal tool????
Thanks!
wahoomcdaniel
08-02-2005, 11:53 AM
I'm having problems geting the door panel off also (96 Grand Caravan). All screwdrivers tried for the two screws through the map pocket seem to spin. Are these torx head screws and if so, what size? Thanks a lot for any help.
G-man422
08-02-2005, 11:57 AM
dont forget the screw in the little dip on the arm rest of the door.
wahoomcdaniel
08-06-2005, 09:11 PM
Thanks. I got that one.
I finally got the panel off. My first try with a phillips screwdriver was unsuccessful because the tip was too small for the bottom screws. I had thought it was a torx head - it wasn't.
I was surprised to see the cables in the regulator pushing out of the cover over the regulator. I was told by the Dodge parts dept. that the regulator usually breaks before the motor. I've found the part at an auto parts store for $120 vs. the $176 at the dealership (motor + regulator).
Now to just do some research to determine installation instructions for attaching the cables to the window pane and guides.
