My painted Valve cover....
Whtehnda93DXSdn
01-08-2002, 09:10 PM
this is my Valve cover that I painted. I worked on it over a period of 3 days...sanding priming and sanding some more to make sure it was nice and smooth.
Enjoy the pics and feel free to share your opinions....
http://imagem.webphotos.iwon.com/1000021900/1000021900_12142001113204AM0.731361.jpg
http://imagem.webphotos.iwon.com/1000021900/1000021900_12142001113200AM0.1471063.jpg
http://imagem.webphotos.iwon.com/1000021900/1000021900_12142001113209AM0.4445089.jpg
http://imagep.webphotos.iwon.com//1000021900/1000021900_12142001113546AM0.3037989.jpg
Thanks for looking :frog:
CivicEx95
01-08-2002, 09:13 PM
Looks nice, matches the rest of the under-the-hood stuff. Too bad is still a DX
CivSiGuy
01-08-2002, 09:18 PM
I hope my painted cover gets rid o your blues..
3hour job by the way.
http://communities.msn.com/_Secure/0NABvbqISFvGIM52RrH1f38!qiSuyD6UT!HIN4l7*IhkwL3eLn Wsy6oSYsnu90MS4US1MJcwvmV6vGFqZWQHQIA/red_engineclose.jpg
http://communities.msn.com/_Secure/0MgAAAMgRSsaIM52RrH1f3wM4zadteZNIspdPVoiwP0EpilfQ* BTAGbQEfuMrXt7afuf15UH0x7uI9Ggav75ajA/red_enginebay.jpg
Whtehnda93DXSdn
01-08-2002, 09:24 PM
thanks for the feedback and yeah it's still a DX but it will be changed one day....
As for working on it for 3 days I was waiting for my new clutch and my ride was sitting for a week so I made use of the time....:D
j.fuggi
01-08-2002, 09:26 PM
what kind of paint did you use? and where did you get all those yellow hoses. i want to paint my valve cover glossy white and resleeve most of my hoses with white.
also... i have an aem cai thats gray. i was thinking to myself while taking a shit earlier that it would look cool to paint it glossy white too and outline the white AEM sticker with a black sharpie marker! possible? or would the paint crack from too hot or too cold?
CivSiGuy
you can tell you took your time, it is extremely smoothe :)
Whtehnda93DXSdn
01-08-2002, 09:41 PM
WEll I did a base coat of Yellow heat resistant paint then after that I applied about 3-4 coats of Yellow krylon.
The yellow hoses that you see are one of the Yakimara-sp hose kits. I actualy used those to replace the stock black hoses. Most peopel just cut the colored hoses and place them over the stock ones but I didn;t want to do that when I didnt; need to.
as for painting your CAI there isn't anything wrong w/ doin that at all. It would lok good and match the overall loo under your hood. I would say go for it. As for the Outlineing of the AEM on it I would say use a paint pen in black not a sharpie marker...
Hope this helps....
j.fuggi
01-08-2002, 09:53 PM
Hope this helps....
would i need heat resistant paint for the intake since it is under my engine and it gets pretty hot under there. and wont the krylon get fucked up after heat? dont you have to use all heat resistant paint when you paint the valve cover?
THEY DONT SELL KRYLON ANYWHERE OVER HERE ANYMORE!! WTF?
i searched google.com for Yakimara sp but got no results. any online stores with this product?
Whtehnda93DXSdn
01-08-2002, 10:06 PM
Well I've had mine painted like that for quite a few months and haven;t had a problem w/ it looking any diff. I also just wanted to keep the same yellow through out my ride.
as i said i did mine w/ Krylon but yes it would probably be better to go full Heat resistant paint.
as for the CAI i would say just use the same piant you do end up using for the valve cover on teh CAI so that way as I stated befroe it looks uniform.
My hoses I ordered from www.summitracing.com and I found it and it's the Akimoto hose kit in Yellow.
hope this helps additionally....:frog:
CivSiGuy
go to the local ho-hum autoparts store and buy this paint called "Engine Enamel" EVERYONE has it
jimmyfunk
01-09-2002, 12:06 AM
looks really smooth...great job
Whtehnda93DXSdn
01-09-2002, 12:10 AM
thanks for the feedback jimmyfunk.....
Welcome aboard AF by the way....:frog:
SilverY2KCivic
01-09-2002, 12:14 AM
Very nice job there, Whtehnda93DXSdn. :D I love the look of it, so smooth and glossy looking. Did you clear coat it any after painting? I would like to paint up my valve cover to my motor, but I don't have the time to, and I need my car everyday, so it wouldn't benifit me to have it out of commision a few days. :( Plus I'm worried that once I'd put the painted cover back on, it wouldn't be sealed on the block as well as it is from the factory. Did you or anyone else that has done this. had any problems with the cover leaking any oil through the gasket seal after taking it off and putting it back on? Here's how my engine looks so far:
changedagame108
01-09-2002, 12:19 AM
Great job on painting that valve cover! It looks smooth, clean, and professionally done. Keep it up! :)
Whtehnda93DXSdn
01-09-2002, 12:25 AM
Thanks changed and SilverY2KCivic....I appreciate it..
SilverY2KCivic No I got such a good finish from the last 2 coats of yellow that I never ended up clearing it. I was goin to but never have taken it back off. I didn;t have any problem w/ mine resealing when I put it back on. Just make sure to have it setting right and just tighten it down to the right amount of torque.
Hope this might help.... :frog:
SwtNLowShanna
01-09-2002, 01:06 AM
very very nice...
Makes me wanna go out in this 15 degree weather and do mine. :eek:
But yeah.. impressive.
Whtehnda93DXSdn
01-09-2002, 08:38 AM
Thanks SwtNlo..I appreciate the feedback....
I would say wait til it warms up unless you have a nice warm area to do it at...:frog:
sparq
01-09-2002, 03:37 PM
Originally posted by SwtNLowShanna
very very nice...
Shanna will you marry me? :cool:
