Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Avalanche/C&K/Silverado/Suburban/Tahoe > C/K
Old 03-29-2004, 08:57 PM   #1
gasjake
gasjake Normal reputation
1988 that will not start if hot
OK, This is the weird thing. I can start my truck and go for a few miles turn it off, and it will be fine to start right away. If I go for more than about 20 minutes and turn it off, I have to wait about 15 minutes before it will crank. The engine just does not turn over. i have replaced the starter, and that was not the problem.
any ideas?
Thanks in advance
gasjake is offline   Reply With Quote
Old 03-30-2004, 12:16 PM   #2
Ezee5
Ezee5 Normal reputation
Re: 1988 that will not start if hot
Do you have a heat shield on the starter? Also you could check for bad connections.
Ezee5 is offline   Reply With Quote
Old 03-30-2004, 02:20 PM   #3
gasjake
No heat shield?
Do i need one? I have checked the wiring, but it could be that the wire to the starter gets too hot and expands. Does that sound reasonable? I guess I could change the wire to the starter.
Old 04-01-2004, 09:59 PM   #4
Ezee5
GM use to have factory installed heat shields back then. If the starter was ever replaced it might not have been re-installed.
Once the engine warms it heats up the starter and once the starter gets to a certain temp it doesn't want to work.
You might be able to get one at a salvage yard or parts store. Here's what they look like.. (sort of)
http://www.apexembeded.com/car-parts...at-Shield.html
Old 04-02-2004, 08:01 AM   #5
gasjake
Re: Re: 1988 that will not start if hot
Thank you! I do not have one I will see if i can find one in a junk yard
Old 04-04-2004, 08:40 AM   #6
michelq
michelq Normal reputation
I think you have alarm on your truck you need to pull starter wires from alarm system and put them back like it came from factory
michelq is offline   Reply With Quote
Old 04-08-2004, 02:31 AM   #7
Ezee5
Re: Re: Re: 1988 that will not start if hot
How'd ya make out ? Hope all is well.
Old 04-08-2004, 08:17 AM   #8
gasjake
I have found a heat shield, and will put it on this weekend. My truck is a third car for me and the wife so no hurry. I will post the results after I get it done.
Thank you
Old 04-14-2004, 09:50 PM   #9
StrokedOne
StrokedOne's Avatar
StrokedOne Normal reputation
Just some insight,
I run full length headers and no heat shield. I have an Auto Zone starter and have had it for two years. I thought it was a heat problem too when mine started to do the same thing. Turned out the battery was on the blitz. It takes more umpf to start a hot engine than it does to start a cold...just a heads up that it just might be a weak bat....
Nothing better than my small block out running a car with a big block, ...except when that small block is in a truck.
StrokedOne is offline   Reply With Quote
Bookmarks
Google
Web AF
