1991 integra gs specs?streetrcr45 03-28-2004, 11:46 PM i looked really quick to find some specs for my gf's car but i didnt come across anything...\ so... can someone give me a list of some engine specs for the 91 integra it would be very much appreciated. riceroni 03-31-2004, 04:50 AM 2nd Generation Integra Specifications (USDM Models) 1990-1991 Acura Integra Courtesy the 1991 OFFICIAL ACURA Sales Brochure ENGINE AND ELECTRICAL Engine Type 1.8 L, DOHC, 4-cylinder, 16-valve Engine Block Aluminum alloy with cast-iron cylinder liners Horsepower, SAE net 130 hp @ 6000 rpm Torque, SAE net 121 lbs.-ft. (16.8 kg-m) @ 5000 rpm Induction System Programmed Fuel Injection (PGM-FI) Transmissions 5-speed Manual or Electronically controlled 4-speed dual mode automatic with lockup torque converter. Drivetrain Transverse front-engine/front-wheel drive with equal-length halfshafts Front Suspension Independent double-wishbone with coil springs and stabilizer bar Rear Suspension Independent double-wishbone with coil springs and stabilizer bar Steering Type Speed-sensitive, power assisted, rack-and-pinion Tires 195/60 R14 85H (RS) Michelin MXV 195/60 R14 85H (LS and 4-door GS) Michelin XGT-V P195/60 R14 85V (3-door GS) Braking System Dual-diagonal, power-assisted 4-wheel disk brakes. Anti-Lock Braking System: Honda-designed system with 4 wheel-speed sensor and electronic control unit (GS Models) Fuel Capacity 13.2 US Gallons (50 Liters) Recommended Fuel Unleaded Regular 87 ([R+M]/2) EPA Fuel Mileage* (City/Highway) 24/28 mpg (5-speed) 23/28 mpg (Automatic) 3-Door 4-Door EPA Passenger Volume 79 cu. ft 85 cu. ft. EPA Cargo Volume 16 cu. ft. 11 cu. ft. EPA Total Volume 95 cu. ft 96 cu. ft Curb Weight 5-speed Automatic 2560 lbs. (1161 Kg) 2615 lbs. (1186 Kg) 2606 lbs. (1182 Kg) 2661 lbs. (1207 Kg) Coefficient of Drag 0.32 0.34 EXTERIOR DIMENSIONS 3-Door 4-Door Wheelbase 100.4 in. (2550 mm) 102.4 in. (2600 mm) Track, Front 58.1 in. (1475 mm) 58.1 in. (1475 mm) Track, Rear 58.1 in. (1475 mm) 58.1 in. (1475 mm) Overall Length 172.9 in. (4392 mm) 176.5 in. (4484 mm) Overall Width 67.5 in. (1714 mm) 67.5 in. (1714 mm) Overall Height 50.0 in. (1270 mm) 50.6 in. (1285 mm) streetrcr45 04-01-2004, 01:27 AM thanks alot man Automotive Network, Inc., Copyright ©2012
