Previa running warm96 previa 03-27-2004, 06:53 PM I have a supercharged 96 Previa with 130,000 miles. About a month ago it started running warmer than normal so I thought I would replace the water pump and thermostat. Both purchased at Toyota. This did not fix the problem. The next thing I replaced was the radiator. The fan clutch seems to be ok it was replace about 40,000 miles ago. The only thing I can think of is that the hoses are collapsing and restricting flow. lwbsda 06-28-2006, 05:29 PM I have a supercharged 96 Previa with 130,000 miles. About a month ago it started running warmer than normal so I thought I would replace the water pump and thermostat. Both purchased at Toyota. This did not fix the problem. The next thing I replaced was the radiator. The fan clutch seems to be ok it was replace about 40,000 miles ago. The only thing I can think of is that the hoses are collapsing and restricting flow. Did you ever find out what the problem was? jackass#1 07-03-2006, 06:24 AM try flushing you system out. could be a partial blockage somewhere internal. do a reverse flush to loosen anything(dirt, rust,and ect.). Automotive Network, Inc., Copyright ©2012
