power slider
Frankie_D
03-24-2004, 01:33 PM
Recently my power slider quit working. It worked fine when we got in and then would not work to let us out. There are no sounds (motor or latch) coming from the door. I have looked for a fuse but have not found any. Any suggestions?
dmburrows
04-12-2004, 06:50 PM
Most likely your battery is low. If you have an owners manual the instructions are listed there. If not let me know and I will look in mine and send it on.
Frankie_D
04-16-2004, 03:45 PM
The battery is new and the system is charging fine. My onwners manual does not say much about the power door.
bmfzo6
05-05-2004, 12:15 PM
with the key off and the slider closed remove the tail fuse for 30 sec. reinstall and cycle the door with either switch. or try and open the door and close it manually after reistalling the fuse then try the switch
