my hazard lights don't work
ThugginCivic
03-23-2004, 06:28 PM
when i bought the car the switch didn't turn on the lights. what could it be
cvcc_wagon
03-23-2004, 07:07 PM
bad fuse?
QuackerStacker
03-28-2004, 07:17 PM
is there a battery in the car?
ThugginCivic
03-28-2004, 09:48 PM
why wouldn't there be?
cvcc_wagon
03-28-2004, 10:11 PM
look at his avatar if you are confuised. :naughty:
QuackerStacker
04-02-2004, 04:24 AM
hahahahaaa well some times it is the obvious that is the problem ...
newtoimport
09-25-2004, 02:59 PM
mine dont work neither can someone help
mellowboy
09-25-2004, 05:07 PM
Check the fuse.
Figori
09-25-2004, 06:03 PM
The hazard fuse is located on the positive terminal harness on your battery.
newtoimport
09-26-2004, 03:12 PM
still dont work my blinkers work but not my hazards it make a wierd sound when i turn my hazard lights on like zzzzzzzz can some one give me advice on what to do i need it for inspection sticker thanks
newtoimport
09-26-2004, 10:14 PM
thanks they work now it was the harnes it was bad
BarryP
11-19-2004, 03:14 PM
If it's not the fuse, then most likely the hazzard switch is corroded or bad. Take the steerting wheel collor off and clean the contacts with some contact cleaner. If that doesn't work and your fuse isn't blown, you most likely need a new switch.
