Courtesy lights under side view mirrors.denalio34ceo 03-23-2004, 03:04 PM Has anyone replaced these on an '03 Denali? If so, what is the bulb part number? Thanks. Eggert 04-15-2004, 09:39 PM Hi, on a 2001 non Denali Yukon it is like a TV remote batery door - you push a little tab to the side and then you can pull the puddle lamp out. There are 2 small phillips screws to get at the bulb. Trade Number is 211-2. Hope this helps, Eggert. :bananasmi denalio34ceo 04-15-2004, 10:52 PM Thanks Eggert. I got to it and replaced it with a hyperwhite Raybrig light. rzkz8k 04-16-2004, 09:50 AM Thanks Eggert. I got to it and replaced it with a hyperwhite Raybrig light. Where did you get the hyperwhite replacements? Thanks denalio34ceo 04-16-2004, 10:58 AM You can get find them online. In your search engine, type in "Raybrig dome" or "Polarg dome". Polarg M28 and Raybrig R117 (both hyper white) are direct replacements. The bulb measurement is 1 7/16 in. (36.5mm) by 3/8 (9.5mm). rzkz8k 04-16-2004, 12:00 PM Found them, thanks. Are they worth the $$$'s, at around $18 each I want the side of my truck to look like a 747 coming in for a landing :). denalio34ceo 04-16-2004, 05:38 PM I did it primarily to match all the other hyperwhites which were PIAA's. $18 is rather high. Keep searching because I purchased mine for about $12 with shipping. It won't look like a 747 but the lights will look consistent all around if you're going all hyperwhite. Automotive Network, Inc., Copyright ©2012
