Alero coolant sludge problembruno4 03-22-2004, 09:39 PM Our April 02 Alero 3.4 V6 has done 36K miles. We purchased it as the second owners in April 03 and 22K miles. About 2 months ago, I noticed that in the coolant expansion tank, a brown sludge appeared on the base of the filler cap and on the top and sides of the expansion tank itself. As the Dexcool is supposed to last 150K miles, I was reluctant to drain and change it. Therefore, I flushed the expansion tank and refilled it with the correct ratio of Dexcool and water, but the sludge is happenning again. This is my first time using Dexcool, is this normal? sludge to me is an enemy and should be flushed out. Can anyone help here? Thanks in anticipation. Duby 03-27-2004, 01:21 PM Our April 02 Alero 3.4 V6 has done 36K miles. We purchased it as the second owners in April 03 and 22K miles. About 2 months ago, I noticed that in the coolant expansion tank, a brown sludge appeared on the base of the filler cap and on the top and sides of the expansion tank itself. As the Dexcool is supposed to last 150K miles, I was reluctant to drain and change it. Therefore, I flushed the expansion tank and refilled it with the correct ratio of Dexcool and water, but the sludge is happenning again. This is my first time using Dexcool, is this normal? sludge to me is an enemy and should be flushed out. Can anyone help here? Thanks in anticipation. As far as this stuff goes I haven't had that problem yet... I purchased mine used and maybe this was corrected before I took delivery. This is a common occurence and it does not seem like Olds. has done their research on this... yes sludge is bad, how to get rid of it... check with the dealer for a switch... but I have a feeling that this will be at your cost. petey_z24 04-23-2004, 12:05 PM lots of ppl fluch out the dexcool and replace with normal green stuff. Over at s10furums.com they talk about doing this all the time without any problems afterwords JTrujillo86 04-24-2004, 02:31 AM I would refrain from going the way of the green stuff. I used to have a Malibu, which has the 3.1 V6, which is nearly the same as the 3.4. My neighbor also had the same vehicle I did. He chose the green stuff and I stuck with Dexcool. About 2 weeks after his switch, his water pump took a dump. The mechanic attributed it to the green stuff. Jeremy jamcllw 04-30-2004, 04:04 PM lower intake manifold gasket leak it's notorious in 3.4L motors your oil and coolant is mixing not a good thing hope your under warranty because it costs around $800 to fix DamienZ28 05-10-2004, 11:43 AM Bingo brown sludge in the cap means one thing.. OIL whick on a 3.4 means one other thing.. intake gasket! Mabey it could be a bad head gasket or a cracked head since you were not the first owner but more than likely its the intake gasket. Have looked arounf the intake for any wetness? When they get bad enough you'll see it! Good Luck don't forget to post a answer TY! whdream 05-21-2004, 10:06 AM I agree that sludge was in my reservoir as well. the coolant was that not so lovely brown colour. I did take it in and they told me it was in fact the intake manifold. They did replace it, And so far it has been ok. The price was pretty steep. But again, I called GM Canada, and got something worked out with them. This was a problem with GM Alero's and they were in fact doing a what the call "Good Will" deal with customers. I paid the warrenty rate. which all in all I pai 400 bucks. Rather than over 900. So ask your delearship if they can help you on this, if not call GM headoffice. Bingo brown sludge in the cap means one thing.. OIL whick on a 3.4 means one other thing.. intake gasket! Mabey it could be a bad head gasket or a cracked head since you were not the first owner but more than likely its the intake gasket. Have looked arounf the intake for any wetness? When they get bad enough you'll see it! Good Luck don't forget to post a answer TY! oldmike 05-24-2004, 07:36 AM I have the same problem as all the people above. Just bought a used 01 Alero 3.4 v6 (well, actually wrecked) and am starting the process of fixing it up. I always check mechanicals before starting body work. Noticed immediately that the reservoir tank was full of brown sludge. I'm going to take it off and clean it and while it's off, flush rest of system. Anyone have tips on how to do this? Also, how long can you run the car without the sludge causing problems? May be a while before I get around to taking it in or trying it myself. I'm definitely going to check out the "good will" fix that whdream mentioned. Looks like to me it should be a recall. Thanks, Mike DamienZ28 05-24-2004, 11:19 AM I am the master of putting things off! Well reallyw ith work I haven't had time to do it my self and I normally will refuse to pay a dealer ship or mechanic to do it! BUt your right it really should be a recall! Before attempting to do a flush and fill to clean your system out I would replave that intake gasket first! The sludge will just come back if you dont. Good Luck! jamcllw 05-24-2004, 02:45 PM The gaskets themselves aren't hard to change just very time consuming and very easy to get lost in the project. If you decide to do it yourself take your time and make sure you label everything so when you are putting it back together you don't have to search for the connections. whdream 05-25-2004, 08:09 AM As per the "Good Will" fix by GM. This does have requirements. They go by the milage of course, and the year of car. Mine was a bit over the milage requirements, but seeing how I had called before they honored this. They did the leg work and called the dealership for me. And set things up. Make sure you get your car in soon. I had a lot of phone calls to go through to get this done. And to be honest I don't really feel any difference in the performance of my car. Other than the smell of coolant. I agree that sludge was in my reservoir as well. the coolant was that not so lovely brown colour. I did take it in and they told me it was in fact the intake manifold. They did replace it, And so far it has been ok. The price was pretty steep. But again, I called GM Canada, and got something worked out with them. This was a problem with GM Alero's and they were in fact doing a what the call "Good Will" deal with customers. I paid the warrenty rate. which all in all I pai 400 bucks. Rather than over 900. So ask your delearship if they can help you on this, if not call GM headoffice. 95ragtop 05-25-2004, 06:14 PM Agree with jamcllw. It's not that hard, just time consuming. I had the same problem. It took a long weekend and $35 in parts from E-bay. If you don't have a GM service manual, try the Autozone.com repair guide. They're straight from the service manual. Just don't let i go too long, eventually you'll have coolant in the oil and it will be all over. PS. Some of the guides tell you to "rotate the engine". I skipped that part and had no problems. Good luck. jamcllw 05-26-2004, 08:53 AM I never heard about rotating the engine. I guess I skipped that part too. DamienZ28 05-28-2004, 12:23 AM Well I jinx myself in this post about the head gaskets.... My wifes 99 Montana witht he 3.4 lost a head gasket and its a bear of a job! I will never do this job myself again! Be warned! Its really a tough job. If it was on my alero id be done already at the same amount of time it took to get the montana's motor half apart! scrt79 06-06-2004, 09:53 AM yup, definately intake gskts.... after you replcace them, or i should say, DURING... make sure to get the NEW updated bolts... and torque them to specs... the gskts have changed, and the bolts have also. after you replace them, i have heard of the coolant swap as well, might do you good. :D oldmike 06-07-2004, 07:53 AM yup, definately intake gskts.... after you replcace them, or i should say, DURING... make sure to get the NEW updated bolts... and torque them to specs... the gskts have changed, and the bolts have also. after you replace them, i have heard of the coolant swap as well, might do you good. :D SCRT79, You sound like maybe you work for a dealer. What does the new gasket plus bolts cost? About the coolant swap you mention, is this a swap from Dex-Cool to green stuff? Also, in another post talking about the tire rub problem, it sounds like you are saying the dealer might replace for free. Is that true? Thanks, Mike jamcllw 06-07-2004, 10:35 AM The new bolts are nothing more than bolts with threadlocker on them. You don't have to buy the new bolts just make sure you clean yours very well and run them through on of those things that re thread bolts(couldn't think of the name of them) and then just put locktight on the bolts. You don't have to spend the money on new ones. Also check ebay for the gaskets I got the updated gaskets for $20 shipped to my door. Look to spend around $50 or more from the dealer and most parts places like autozone or pepboys don't have the updated gaskets. And the only difference between the old gaskets and the new ones is that there are two little metal cylinders by the bolt holes that prevent you from over torqueing the bolts and cracking the gaskets. scrt79 06-07-2004, 01:44 PM in CDN funds :( they list at approx $98.01 and that is just for the upper and lower gskt kits. as far as the tires go.. there IS a possibility of a replacement"au gratis" but prob only for the front 2 tires. scrt79 06-07-2004, 01:44 PM p.s. yes i do work for a dealership DamienZ28 06-07-2004, 02:17 PM On mine I used new head bolts that a must since the tourqe is dependant on this. As for the Intake bolts just wire wheel those off and make sure there good and clean. On mine I used red locktight and its working out verywell so far. Oh and as a rule I ALWAYS use felpro gaskets. jamcllw 06-07-2004, 02:58 PM 9 times out of 10 I'd use Felpro gaskets but they didn't have the updated version when I went to get the gaskets so I got the revised kit from GM off of ebay for $20 DamienZ28 06-09-2004, 01:12 PM Wow I was in such a rush to get our montana done that I over looked the crush sleeves EEK. But I tourqued them down to specs and since its just the intake it shouldnt br half as bad as the heads were... Well almost. You are right though the felpro doesnt have them. I guess Ive blindley trusted felpro for to many years. Ill post if they go bad for some reason, but I do expect them to hold up! I hope! Damien jamcllw 06-09-2004, 03:28 PM I hope you know when GM found out about the gasket constantly failing they released new torque specs. That was the reason they were all failing is because they were torqued too tight. DamienZ28 06-16-2004, 10:37 AM Yeah I used the new specs, but it did seem really loose feeling. Oh well I used locktight so they should hold fine. Like I siad ill post if they fail. jdeemer 06-17-2004, 11:26 PM I don't recommend switching over the antifreeze to the green. If you use dexcool and distilled water you'll be fine. Why distilled? G.M. has a service bulletin out recommending it to reduce corrosion and sludge in the system. oldmike 06-18-2004, 07:53 AM jdeemer - I agree. I'm not planning to switch from orange DexCool, I've had it in several cars now, and have had no problems. jamcllw - Can you tell me the updated gaskets' part number and if you've seen any still for sale on eBay? Also where can I find the new torque specs? What all am I looking at pulling off the top of the motor to get to the lower intake gasket? Thanks Guys, Mike Automotive Network, Inc., Copyright ©2012
