Re: cruise control problem w1500
I had the same problem, there has been a technical service bulletin (TSB) issued to address the cruise control trouble. The TSB number is "TSB 08-22-97 Rev A". You can find it at genosgarage.com, or any Dodge dealer will have it. It will describe the problem and how to fix it. The trouble is that the speed control vaccume hose is located under the battery tray and acid is dripping down onto the hose and damaging it causing it to lose vaccume. This is one of those problems you could chase for the rest of your life and not fix, but when you know the answer it seems pretty simple.
What it amounts to is buying a new hose and putting a battery mat in the tray, but make sure you read it there are some details they suggest, plus they give you the necessary part numbers.
