Time for a Clutch Change
Google
Web AF
Dprotech
05-02-2001, 09:36 AM
:( Car is at 56K and I can feel the clutch beginning to slip. I'm gonna change it but wanted your input on what to put on next.
Also I'd like to know how often a clutch should be changed ...
Some info for you ...Infiniti warranties the clutch up to 20000km
So to summarize ..please write about;
Clutch Change Interval
Clutch Choice
Where to get
Thanks ...
:frog:
Nismoboy1
05-02-2001, 12:18 PM
I'm assuming you have a 99 g20:
I'm not sure about how often you need to change your clutch, it all varies depending on your driving style. I've seen a clutch go out under 10K miles because this guy drove his car kinda hard. But as for availability, the only company that has one readily available is Unorthodox Racing, that I know of. Their webiste is www.unorthodoxracing.com they have a stage 1 and a stage 1+ setup. Both setups are gonna be around ~$500 USD. Stage 1+ being the better one of course. The website also has a dealer locater, so you can find someone around you maybe. Theirs more info on these clutches on their website.
Also www.performancemarket.com/clutches.htm its a list of clutch manufacturers, some of those companies here maybe able to make a custom one for you, cost is up to them though.
Some of the good comanies would probably be ACT, Centerforce, Broward, and Clutch Masters. Good luck
Google
Web AF
