Waterpump change outjaynuke 03-20-2004, 03:37 AM Any advice on changing out the waterpump on a 95 LXi. Just trying to drain the Rad. is driving me nuts. Have changed the water pump & plugs/wires/cap & rotor. Found out that one of the first things to do is remove the P/S Pump bracket from under the car, coming from around the exhaust. Next time, I might just pull the engine. Also, I believe that this is just a fluff board & will try to find a board with more support/info. Mister-X 09-26-2004, 01:19 AM My advice is to find someone that'll do it for cheap and then sell the DEMON POSSED car... We have one 2 and it has been nothing but problems, also we have a leakin water pump... gota take apart alot of stuff just to get to it... change out the timing belt if you do sinc you have to take it off just to get to it. vBulletin®, Copyright ©2009, Jelsoft Enterprises Ltd.
