Head Light Problem, Very Strange Need Help
snowgoer1999
03-20-2004, 12:03 AM
Put New Bulbs In . The Slyvania Silverstar Bulbs, My Fog Lights Work In Its Normal Postion With The Side Marker Lights. Now When I Turn My Low Beam Headlights On My Fog Lights Go Off And The Low Looks Light A High Beam. I Switch Over To The High Beam. The High Beam Is Bright And The Low Beam Is Still Bright. So Both Bulbs Are On There Highest Setting. I Took Out All The Bulbs And Put One Bulb In The Low Beam Postition. Now My Fog Lights Work With The One Bulb. Next I Put In The Other Low Beam, Instantly Both Low Beams Become Very Bright And I Lose My Fog Lights. The Quad Beam Relay Is Clicking Each Time I Remove The Plug From One Of The Low Beam Bulbs. Now Has This Ever Occurred With Another Ram. I Cant Seem To Figure This One Out. Thanks Chad
malcolm brumley
03-21-2004, 11:44 AM
I had something almost like that happen and found that the ground wire inthe bulb socket wasn't making up to the bulb. When I finally got it to make contact with the bulb contacts it worked right.
snowgoer1999
03-21-2004, 12:55 PM
Thanks i will give it a look over at the ground connections . It was weird one bulb blew then replaced them and they are goofy now. Also Anyone have there abs system go out. No light comes on. Was on a little ice the other day and nothing happened. Is there a switch in the rear axle for the a b s that might fail?
malcolm brumley
03-21-2004, 02:43 PM
My trailer hitch wiring connector shorted once and blew a fuse then my abs light was on untill I replaced the fuse.
