Speedometer ProblemBobMaio 03-18-2004, 04:59 PM I have a 94 pathfinder 4wd and the speedo does not work and the "check engine light" is on. The computer error code indicates that the speed sensor has failed. My first reaction is that the speedo cable has failed which prevents the speed sensor from reading anything. But that is just a guess. Before I spend hours taking the dash apart, can somone help me out here? Is the cable at fault as I suspect or is it just the speed sensor. I find it hard to believe a cable fails today. I haven't seen one go bad since the 60s. Also, where the heck is the speed sensor located? Can somone with more experience on this explain the steps to change the cable and or sensor can be changed? Automotive Network, Inc., Copyright ©2012
