16v inplace of a 8v1995 geo tracker 03-17-2004, 09:15 PM the engine in my wifes 95 tracker tossed a rod the other day , i was checking around to get the prices of used engines , what i want to know is , can i use a 16v SOHC long-block in place of the 8v without having to do anything other then swap the intake and other stuff off the 8v ? thanks for any help with this John_Johnson82 03-23-2004, 11:28 AM *The pistons in a 16v motor have 4 valve reliefs where as the 8v will only have 2 reliefs per piston.* As far as I know the block, crank and everything are the same the pistons are the only difference. Im not for sure is you can swap a 16v short block to a 8 vlave head because im not sure where or how far the valves drop, swapping might cause you to have the valves smacking your piston but dont quote me on that because im not for sure. 1995 geo tracker 03-23-2004, 12:14 PM i don't want to reuse the 8v head , i want to use a 16 v long block , just want to know if i am going to have in problems using the 8v intake , exhaust , and the distributor Automotive Network, Inc., Copyright ©2012
