ABS/DSC/Brake warning light onerindyer 03-17-2004, 04:28 PM Recently the above warning lights are coming on. The ABS sensor and relay appear to be operational. I have a 00 740il (E38), does anyone have insight into this problem? Also, where can I find a ABS control module? Thanks, T libertylover 03-18-2004, 06:23 AM You might try the E38 board of www.roadfly.com for more info but I wouldn't drive very long with warning lights lit concerning the BRAKES. jwilli328 03-29-2004, 09:52 PM I have the same problem with my '00 740il. I just pulled it back from the dealer today. The problem with my car is the DSC controller(traction control). The dealer wants $2200 to fix the problem. My car is 6500 miles out of warranty. I have another mechanic that tells me this my be a dealer only item. The error code that my car sends is #33. Your problem my be an ABS controller. Similar error codes but $700 to fix. The problem, I have been told, does not effect the brakes. The brakes still work. You will not have ABS or traction control, drive carefully. erindyer 04-07-2004, 06:11 PM Well the problem was the Abs Control Module. The dealar wanted $1700 for the part. I declined and bought a brand new Bosch module on ebay for $200. I had BMW dealer install it and reset it. All is fixed for about $400 total vs. the $2200 estimate from the dealer. Automotive Network, Inc., Copyright ©2012
