What else do I need???
Phat_Si
01-06-2002, 09:27 PM
To make a custom turbo kit for my car, what else would I need besides:
- Turbo
- Intercooler
- Boost Guage
- Boost Controller
- Manifold
What else do I need? Thx in advance!!!
- Phat_Si
Si 2 Si
01-06-2002, 09:30 PM
blow-off valve, and a few other other things. Do you plan on making this from scratch?
Phat_Si
01-06-2002, 10:29 PM
Yea, thats why I need to know everything!!! :)
drift
01-07-2002, 01:44 AM
turbo
matching manifold
downpipe with flange for turbo and cat converter
flexpipe
wastegate or popoff valve
blow off valve
intercooler
lots of piping
silicone hose and clamps
some type of fuel management setup to increase fuel in accordance to boost levels (Vortech FMU is cheapest, Greddy rebic with additional injectors is better, standalone is best)
flanges for BOV and wastegate (if external)
oil return flange
t-connector for oil feed
hose for oil feed and return
hose for coolant feed and return (if the turbo has a water cooled housing)
upgraded fuel pump (if going into a civic, the stock Prelude H22 pump is fine)
MAP sensor check valve
boost gauge
air/fuel ratio gauge (for fuel tuning)
stage 2 or better clutch
LSD if not so equipped (or you'll be replacing one tyre each month if u drive it hard)
1 or 2 step colder spark plugs
MSD Boost Timing Master or equivalent ignition timing setup if you plan on riding the fine line of max boost on stock internals.
Turbo timer for convenience sake
if you plan on installing this yourself, get competent with a MIG welder so as to weld the oil return flange to your oil pan. this is the most reliable way to do so. also, you'll be welding more than a few of the intercooler pipes together, and also the downpipe and any bungs for O2 and EGT sensing.
if you need help, lemme know. i just did a junkyard turbo setup on my prelude. i am also now selling kits for cheap... they include most of the above, but some welding is required for assembly.
Phat_Si
01-07-2002, 07:14 PM
How much are your junkyard turbo kits??? I'm interested. It's for a Zc. Thx.
- Phat_Si
spy54
01-07-2002, 07:57 PM
lol drift just worked you crap thats alot of shit,.... how where is the number to greddy....:p
drift
01-07-2002, 09:13 PM
- Phat_Si
about $1200-1500. i'd have to look up all the parts for your application and compile the prices.
the turbo will be spec'd at your motor size and output for maximum performance, and rebuilt and spin balanced to ensure it's 100% reliable.
even tho it will be a complete kit, some major assembly will still be required, so it aint for any shadetree mechanic... but at least it will guarantee you have everything you need to make it work instead of shopping around for parts.
Phat_Si
01-07-2002, 11:23 PM
You think if I get my own Ic, and turbo and stuff piece by piece, that I could buy the stuff I need from you piece by piece???
