transmission overdrive in and out
manning-2
03-16-2004, 04:26 PM
My 96 pathfinder's auto transmission overdrive cycles on and off
on the interstate. Any hints would be greatly appreciated.
Thanks
lewisnc100
03-17-2004, 07:16 AM
Thanks
Is the check engine on? Mine was floating between gears when my TPS (throttle position sensor) was out of adjustment but it also gave me A/T gear ratio errors. How's your transmission fluid level and condition?
manning-2
03-17-2004, 11:08 AM
Replaced TPS. No check engine light. Tranny fluid good. Thanks for reply
lewisnc100
03-17-2004, 01:22 PM
When you replaced the TPS did you go through the adjustment procedure?
manning-2
03-17-2004, 04:18 PM
Dealership replaced it and I've had it back 3 times,
with no luck on them repairing problem. So here I am looking for clues. thx for reply
micky k
07-01-2008, 09:10 PM
Hi there,
Did you fix this problem as mine does the same thing and i would like to no what the problem is??
Garybaumgartner
12-14-2010, 12:11 AM
Hey anyone figure this out? I have a 96 and it's doing that to but its only when its cold. I leave my heat off it has no problems but when its on at all it does it! And when its cold it takes awhile to shift into OD anyways. I just changed the tranny fluid 2 months ago.
micky k
12-14-2010, 02:26 PM
I fixed the problem in mine by disconnecting the gearbox temperature sensor at the computer end. It is a problem with the sensor. Hope this helps
