Need GST help!!
SpdLuvr
03-16-2004, 12:27 PM
Ok, need a little wisdom of the gurus. 95' GST most time runs fine then at idle will start to miss, it only does it once in a while, i stop at a light and it starts to act like its going to die. i touch the gas and its fine till the rpm comes back down. just lately i've noticed a couple times if it sits and idles for 5 or 10 mins once i start out again and step on it, it will loose power for just a second then the turbo spools and goes on fine. i've changed the plugs & wires even got desperate and try injector cleaner (I know) maybe i'm missing something but i'm starting to get a headache bangin it against a wall....ouch..any help is greatly appreciated..Thanks!!!! :banghead:
805ace
03-16-2004, 01:58 PM
It could be your throttle body because that happened to me before and they told me the throttle body needs to be clean, It may mean that your not getting enough air to the engine..
LandoAWD
03-16-2004, 02:18 PM
Bad coil, perhaps.
This sounds very fuel/spark related.
