Automotive Forums .com - the leading automotive community online! Visit IgorSushko.com and see what it's like racing in Japan
Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Honda > CR-V
Old 03-16-2004, 12:05 PM   #1
babarn
babarn Normal reputation
Question Strange Sound 2001 CRV
Hello. I was wondering if there was anyone here that experienced or are experiencing a strange sound when:
1. From a complete stop, on an uphill incline, you press on the excelerater and a shreeking sound (not the tires ... lol) emits.
2. I can produce that same sound on a very hard steer (postion the steering wheel all the way till the steering wheel stops turning)
Not sure where the sound comes from.
Anyone?
babarn is offline   Reply With Quote
Old 03-16-2004, 06:40 PM   #2
surgicaltech
surgicaltech's Avatar
surgicaltech Normal reputation
Re: Strange Sound
Sounds like it could be the engine belts,specifically the power steering belt...
surgicaltech is offline   Reply With Quote
Old 03-16-2004, 09:52 PM   #3
jgr7
jgr7 Normal reputation
Re: Strange Sound
I'm not sure if this is what your are having.
Have you changed the oil in the rear differential?
I had what honda called a moaning sound from the rear end, in my car this happened when I would make a wheel turned to lock u-turn in either direction. The tech bulletin stated that the rear differential CVT fluid should be changed to correct this problem.
They said it should be done at 60k miles instead of 90k if used in extensive 4-wheel driving, however mine had only been to the snow 1 time. Here is what happend I guess the oil gets contaminated with some crap from the limeted slip inside the diff and causes the noise. I know this sounds strange but it worked on my 98 cr-v ex. The dealer gave me a copy of the Honda ServiceNews from Jan 2000 that had this info.
Jeff
jgr7 is offline   Reply With Quote
Old 03-21-2004, 03:20 PM   #4
lorunner
lorunner
yeah rear diff. thats the noise its a really load howl. change the fluid its relitively inexpensive
lorunner is offline   Reply With Quote
Old 05-06-2004, 02:12 PM   #5
babarn
Re: Strange Sound
That was it!! The rear diff fluid!!! Thanks guys!!!!
Old 05-25-2004, 06:37 PM   #6
Gerbster
Gerbster Normal reputation
Re: Re: Strange Sound
What is the procedure for changing the fluid? Is it like changing engine oil? Is there a hole for filling it back up?
Gerbster is offline   Reply With Quote
Old 06-03-2004, 03:49 PM   #7
babarn
Re: Re: Re: Strange Sound
Took it to a dealer. It took them about 30 min to get the car in and out.
Old 02-11-2007, 12:18 AM   #8
toolman34
toolman34 Normal reputation
Re: Strange Sound
Rear diff fluid (dual pump fluid) is about 12 bucks a quart. at a honda dealer. Make sure you buy at a dealer, not worth the risk buying somewhere else!!!diff hold 1.1 quarts on the first generation model. It is designed to capture particles of clutch pack in the fluid and will cause horrible noise when dirty. If real dirty, buy 3 quarts, change once, drive about a week, then change again!
toolman34 is offline   Reply With Quote
Bookmarks
Google
Web AF
