My 1986.5 NA wont fire Across any cylindersstreetracer_X 03-16-2004, 09:57 AM My 1986.5 NA supra wont fire across any of the cylinders. i have replaced the ECU, the Coil and Ignitor, the fuel pump, Head Gasket, and the spark plugs. plus a few more things i'm sure. I had the Car running and then it just died while driving. then i let it sit for a little while and it started back. it did the exact same thing again except this time it wont start back any idea what the problem could be??? DaMoNe6969 03-16-2004, 01:51 PM Are you getting any engine codes?? I had the same problem with my 90' turbo last summer.. Sometiumes ide drive for 5 miles.. sometimes it'd drive a mile, sometimes it wouldnt start, I was getting an Ignition code.. After replacin a few parts, I found a burnt wire in the harness behind the engine.. I think it got too close to the egr cooler, or something back there.. Just a suggestion Good luck gelcol 10-24-2010, 06:06 PM or check the water temp. sensor or wires plastic connections. Automotive Network, Inc., Copyright ©2012
