Blinker Problem
ghost187
03-15-2004, 06:48 PM
i used to have those cheap hyperwhite bulbs that you can get off ebay that cost about 10 bucks. after about a month, the low beam on the driver's side stopped working, making my left turn signal blink faster than normal. i replaced the bulb with a new set of stock bulbs, which fixed the low beam problem, but still when i make a left turn, it blinks faster than normal. it only does it on the one side and i checked and all the bulbs are still good. what's goin on?
Lac-O-Power
03-15-2004, 07:34 PM
maybe try taking off your battery terminals to reset the computer,it might not realize that you replaced the bulb or something.
GScivic7
03-15-2004, 07:37 PM
did you check front and rear bulbs?
you could possibly have a bad ground too. I believe that's the ricer way of getting hyper blinkers, they just chop the ground wire, and it blinks fast as hell.
ghost187
03-15-2004, 08:02 PM
ya, the back ones are good too, but i'll check out the ground
defmusik
03-17-2004, 01:24 AM
that fast blinker shit is retarded..
xproductionz
03-17-2004, 06:30 PM
anyone ever had the pattern blinkers or the other setup where when you press a button and your whol rear end flashes in a pattern?
jdmcivic04
03-17-2004, 08:40 PM
i may be wrong, and probably are, but somewhere i heard that this was due to a bulb that was about to burn out. i would change your left turn signal bulb and see how that works because it was probably just coincidence that when the low beam burned out, the corner light blinked a lot faster. maybe it'll work, probably not though, but worth a try. sorry if im wrong, im still learning.
