Please Help 2001 Ram 1500 4x4 360 Rough IdleJODYM 03-15-2004, 06:32 PM 2001 Ram 1500 4x4 360 90 000km (Rough Idle) Can you please help me it is driving me crazy :o) When Idling the rpm's fluctuate 50-100 rpm's and the truck shakes a bit as the rough Idle acts up. Truck works great except for this Idle problem. I bought it a few months ago with 82 500km and it has Idled like this since I have bought it, just thinking it needed a tune up. I have tried: New Plugs- Champion New Plug wires- Mopar New Distributor and Rotor Button- Aftermarket New PCV valve- Mopar New K&N air filter Cleaned Idle air control (AIC)valve- Dirty but no difference Cleaned fuel injectors- Removed and sonic cleaned No difference Wynn's Fuel Injection sysytem flush- No difference Took the truck to Dodge and they checked the Intake manifold gasket and vacuum tested the intake- All Ok I only use supreme gas- Tried a few tanks of regular but didn't change at all(it just pinged going up hills under load) Check engine light isn't on Any suggestions or solutions would be G R E A T Thanks Very much appreciated BleedDodge 03-15-2004, 09:33 PM So what's the problem? The truck is running great and everything, and 50-100 rpm isn't that big of a rev... JODYM 03-16-2004, 06:26 AM Problem is that it shouldn't run(Idle that rough). It wasn't built that way. There's obviously a problem and I'm trying to find out what it is. BleedDodge 03-16-2004, 04:55 PM Take it to a dealer. An internal combustion engine cannot run at a dead on rpm... From what you make it sound like, 50-100 rpm isn't much, but if it seems that bad then just take it in... Flormat 03-18-2004, 05:34 PM First, read your owners manual. It will tell you that the engine does not benefit from premium gas. To fix your idle and pinging put 2 new O2 sensors in and you're all done. JODYM 03-18-2004, 08:46 PM Took it to a dealer 3 times Cost me about $950 just on labour charges just trying to find the problem not changing parts. Unless the check Engine light comes on so they can get a code they don't even want to look at your truck. Foolish but it's true. They say there's nothing wrong with that truck :o) I talked to 4 different people with the 5.9L and they have the same problem and they spent hundreds at Dodge dealerships still no luck It's not the miss that bothers me it's the truck shaking so much at a stop light. If I could get rid of the shaking a bit more I would be happy BleedDodge 03-18-2004, 10:21 PM Tell people your truck is shaking with power! Just put the truck in neutral and put your foot into the gas when you're sitting there waiting. It can't be that bad. I can't understand, I'd think it was cool... toivo 04-15-2004, 12:23 PM check your egr valve and see if it is dirty. if it is stuck open you will get a rough idle. also unlpug the vacuum line to the charcoal cannister and block it off and see if the miss goes away. toivo BleedDodge 04-15-2004, 09:16 PM Where is the charcoal canister on these trucks anyways? I was trying to find mine but I don't even know what it looks like... toivo 04-16-2004, 09:12 AM the cannister is a black round cylinder about 9'' high found on the left or right front of the motor compartment, there will be 2 or 3 lines going to it. one will be from the air intake. that is the one you plug. the cannister is about 4'' in diameter. it may be set into a hole in the wheel well. toivo BleedDodge 04-16-2004, 07:31 PM Thanks for replying. I want to check mine. JaKRaBiTT 05-29-2004, 09:39 AM You need to replace your fuel pump. $250 US w/ lifetime warranty aftermarket $430 US at the dealer Automotive Network, Inc., Copyright ©2012
