How do you measure the coolant?
Lat22
03-12-2004, 02:01 PM
I just replaced the upper radiator hose on my mom's 740il and I have no idea how much coolant to replace. I can't decipher the little diagram next to the cap. What if I filled it to the top on a cold engine? Not that I did that or anything. ;)
mastafred
03-12-2004, 03:32 PM
take it to a mechanic and he will hook it up to a gauge goes on top of the cap and measures the pressure
KC Ron Carter
03-13-2004, 12:34 PM
using a 50% mixture of antifreeze in the continental US is OK.
If topping it off just get close to 50%.
It will also need to be bleed to get the air out.
No big deal just a screw to remove and replace when the air is gone.
Then top off the reservoir with 50% antifreeze or premixed.
Later,
morgenhailey
06-11-2004, 05:26 AM
another question about coolent. my 735 runs hot, did the pressure check, everything ok, cleaned the radiator with a spray cleaner solution, meant especially for that, but it still runs hot. what can it be?
