Re: alignment, center link, idler arm
It's your lift causing the problem, I had a 90 with a 4in lift. I had to buy a HD idler, and a pitman arm.
When you raise the truck you change the tie rod angles, and this puts very high forces on the Idler, Pittman arm, and the center link. Consider Heavy Duty after market (if) available parts.
I used Napa, and what a differance.
-Mike
