2002 Sl2 Drinking Oil
tomwhite56
03-10-2004, 12:31 PM
I guess I'm not the only one who's seen this problem. Any suggestions for a later-model SL that seems to suck up oil?
Tom
streetracr32
03-11-2004, 10:37 AM
check compression rings???
slammed4door
03-28-2004, 12:12 PM
make sure that its not leaking it also some saturns have a problem with the leaking as well as the burning. it sucks but there are ways around it. try using a synthetic oil that might slow down the burning process because synthetic takes longer to heat up but if you have a leak it will also find itself into little spots that other oil never did. and the piston rings could be burnt up i doubt it with such a new modle car but you never know.
check out my site
http://members.cardomain.com/slammed4door
PowerStroke
04-03-2004, 10:21 AM
again 1.98 pcv valve. mine sucked oil. 2bucks makes it worth a try
