99 jimmy idles fastksalyers 03-10-2004, 11:19 AM Please help! I have a 99 jimmy sle with 4.3 I can start it up it will idle around 13 rpm in park. When I drive it I don't need to push on the gas, because it will pick up speed and and shift by itself. I guess this is kinda like autopilot in a way. riptreeper 03-10-2004, 11:20 AM sounds like you may have a problem with the gas pedal or with the fuel injection system ksalyers 03-10-2004, 11:50 AM do you know what all in the injection system could cause this??? I put a new tps sensor on it and it did not help. riptreeper 03-10-2004, 11:57 AM no i dont but you should have a mechanic check it out ksalyers 03-16-2004, 12:10 PM I got it fixed. The throttle body had a sensor on the back of it that was bad Automotive Network, Inc., Copyright ©2012
