Fuel Pump? 2000 won't start
suzyq1881
03-09-2004, 12:58 PM
My 2000 Cavalier won't start. It ran fine Sunday and then when I went to start it Monday morning it won't. It acts like it wants to start, but just won't catch. It has good spark, there's gas in the tank and we changed the fuel filter. Still nothing. We think it may be the fuel pump, but when we turn the key we can hear it kick on for 2 seconds, but no gas came out when we had the filter off. Should gas have come out? Do you think it's the fuel pump or could it be something else. Please help!!! I'm without a car.
You can email me at suzyq1881@yahoo.com or post here. Thanks soooooo much.
amac209
03-10-2004, 08:07 AM
how much gas is in the tank?? the fuel gages have been known to have problems on these things. if theres gas for sure and you hear the pump run but no gas comes out like you said then the pump is screwed up or the line to the pump in the tank popped off somehow. theres a pressure test port on the fuel rail it looks like a tire valve if you press it a healthy spray of fuel should come out.
99cavguy
03-14-2004, 02:06 AM
the first thing i would check would be the head gasket.. pernally having dealt with a few blwon ones on cavaliers.. of course its the last thing you check lol.. l8a
suzyq1881
03-15-2004, 05:38 PM
Thanks guys!
It was the fuel pump. All fixed.!!!
Sue
bigdaveangell
03-28-2004, 02:13 AM
If you can hear the fuel pump kick in when you turn the key to run you just replaced a good fuel pump
amac209
03-28-2004, 03:57 PM
sometimes a pump will run but won't build up pressure because the rotor is damaged or the housing leaks.
