Keyless Entry Programming Help for a 2004 Sequoiamisstresmm 03-08-2004, 11:21 PM I need instructions on how to program first time remotes for my new 2004 sequoia. Thanks. You can email me: misstresmm@hotmail.com MYSEQUOIA03 03-09-2004, 12:05 AM Here is the procedure to program additional transponder key for 2003 and 2004 Sequoia 1) Close all doors 2) Insert your MASTER key (BLACK) into the key cylinder 3) Turn the ignition switch from LOCK to ON 5 times within 15 seconds (key end at ON) 4) OPEN then CLOSE the driver's door 6 times within 20 seconds 5) Remove the MASTER key from the ignition switch, insert the blank key in the key cylinder then turn to ON position 6) While the blank key in the ON position, wait 60 seconds or more to allow the blank key register the key code 7) after 60 seconds, remove the key. Open then Close the driver's door to end the process. HINT: You can program up to 4 MASTER key(BLACK) and 2 sub key (GRAY) MYSEQUOIA03 03-16-2004, 10:45 PM Here is the procedure. You must have FCC ID xxxBAN Here are the instructions that I used them to program keyless entry remote for my 2003 Sequoia 1. unlock all of the doors in the car, open the driver's side door, and make sure the key is not in the ignition 2. put the key into the ignition and then pull it out without turning it or anything 3. within 40 seconds, lock and then unlock the doors five times using the power lock button on the driver's side door. 4. close the door and then open it again 5. within 40 seconds lock and then unlock the doors five times again using the power lock button. 6. Put the key into the ignition and turn it to the on position (not acc and not far enough to actually start the engine) and then back to the off position, then back to on and back to off. 7. Pull the key out of the ignition 8. If you are successful, after about 5 seconds, the doors should power lock and then unlock on their own. If that doesn't happen then try again from step 1. 9. within 40 seconds, hold down the lock and unlock button simultaneously on the remote for a second. Then release and hold down the lock button for 3 seconds. The power locks should cycle again once on their own. If they don't cycle exactly once, repeat this step from the beginning with the remote again. 10. Repeat step 9 for every remote you want to program. You have to do this with any remotes that were previously programmed because this process essentially resets what remotes the car will respond to. 11. Close the driver's side door to signify that you are done programming the remotes. misstresmm 03-29-2004, 05:33 PM Does anyone have programming procedures for remote FCC# HYQ12BBX spotco2 04-24-2004, 12:41 AM Does anyone have programming procedures for remote FCC# HYQ12BBX What's that fit? Salocinbake 07-16-2011, 01:41 PM Worked on my 2003 sequoia and a remote: FCC ID HYQ12BBX Thank you. Automotive Network, Inc., Copyright ©2012
