suspension
Google
Web AF
closetbrit
03-08-2004, 08:32 PM
Help. I am just becoming acquainted with my fiances' 1999, 3 series. The service guy says she will need "front thrust rod bushings". I can't seem to locate this item in the shop manual. Is the item called something else ?
tamvegas
03-22-2004, 12:55 AM
Just a guess, but the "thrust rod" sounds like it might be the control arm rear bushing. This is a large rubber press mounted bushing that takes all the horizontal energy for the front suspension (like cruising over spped bumps, potholes and the like).
Skycity_BMW
03-22-2004, 02:23 AM
Closetbrit
This may help, just like Tamvegas said it's the Lower Control Arm Bushing
Check out this web site: http://www.ohiomotorcycle.com/understeer/lcab.shtml
Good Luck
Skycity_BMW
tamvegas
03-22-2004, 03:12 AM
ClosetBrit - Thanks a bunch for the further tip. I had gotten urethane bushings to replace my very worn ones, but because of the heat & dryness out here in the high desert local mechanics will not install them. I was wondering how to get a firmer set and will probably be trying out the M3 bushing recommended in the article you quoted.
Thanks again!
closetbrit
03-22-2004, 04:20 PM
Just a guess, but the "thrust rod" sounds like it might be the control arm rear bushing. This is a large rubber press mounted bushing that takes all the horizontal energy for the front suspension (like cruising over spped bumps, potholes and the like).Thank you tamvegas & Skycity BMW. I do apprecicte the help.
Google
Web AF
