Google
Web AF
See Latest Posts
Go Back   Automotive Forums .com Car Chat > Chevrolet > Cavalier
Old 03-08-2004, 08:17 PM   #1
lvald
lvald Normal reputation
2001 cavalier slow pick up
can someone help me figure out this problem? check engine light flashes when accelerating, code misfire #1 cyl. changed #1 coil pack, plugs & wires, same thing. thanks for any help.
lvald is offline   Reply With Quote
Old 03-09-2004, 06:57 AM   #2
amac209
amac209 Normal reputation
Send a message via MSN to amac209
Re: 2001 cavalier slow pick up
check the compression and the fuel injector. check for a plugged exhaust if it's really slow.
amac209 is offline   Reply With Quote
Old 03-13-2004, 03:38 AM   #3
hgallegos915
hgallegos915 Normal reputation
A good major tune up would not hurt it. Sometimes the ecu goes crazy when u have a bad wire, coil pack..or even a ecu. Change fuel filters and have this baby serviced well.
hgallegos915 is offline   Reply With Quote
Old 03-13-2004, 12:38 PM   #4
neves
neves Normal reputation
also agree to check compression and fuel injector. try a higher octane fuel to prevent detonation. is engine overheating? if the water pump is going out, the farthest piston from the pump will detonate and misfire. also check timing belt...
neves is offline   Reply With Quote
Old 03-13-2004, 05:19 PM   #5
hgallegos915
IM SO HAPPY, turns out that the oil just needed to reach the valves. I cranked it on today and chcked and wala! oil is reaching the valves. Thank you guys for all your help. Water pump and compression seems fine..according to a mechanic I went to.
Bookmarks
Google
Web AF
